Im after a taller diff ratio. Something around the 3.5 ratio or even taller. I have a 3.7 gears here but want to see if I can get something taller before I have it built.
I have heard R33 RB25de auto has a 3.5 diff. Would take the complete centre if someone has one laying around.
Gday, I'm after an R32 GTS-t Manual tail shaft in good condition if anyone can help out, must not have shagged centre bearing/carrier bracket thing like they all appear to - Gearbox Yoke not required either.
Also after some good condition genuine R32 GTR front Guards
Send me a message if you can help - Tobbie - 0401 739 292 Thanks!
  • 3 weeks later...
WTB urgently, the steel water pipes that bolt to the underside of an RB25 inlet manifold, will pay in parts, cash or alcohol!
Will also buy a whole plenum if its cheap/easier.
SMS on 0408 117 171
could try zoidbergmerc he offered me a plenum a couple of weeks ago,
SMS on 0408 117 171
ah oh well
yeah not bad, took it to rons and he managed to take out the old piece and got midas to make up a new piece, now no leaks :D
so its all good, heaps easier than having to replace the whole thing!
now im just waiting for my thermostat to arrive and then im doing oil, fuel filters before powercruise...
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
