Hi All,
I'm after a stuffed RB26 head. I don't care if it's cracked, warped, got a ferret stuck in a port (common problem on RB26's). Only condition is it must be very cheap. I just want it to put on a buggered block I have in the shed and make a dummy engine I can fit in the engine bay and see how everything is going to fit. Basically after something that was destined for scrap metal.
I'm also chasing a slave cylinder, throwout fork and bearing for an R34 GTT box.
Cheers,
Shane
Hi All,
Cheers,
Shane
i have a 20 head you can have if that any use to you.
Thanks, does anyone know if some of the studs on the inlet side line up between a 20 & 26? I know most of the exhaust studs do. If I can get a few to line up then it will do the job for what I'm after.
I'm also after the rear part of an R33 or R34 tailshaft if anyone has one.
Thanks, does anyone know if some of the studs on the inlet side line up between a 20 and 26? I know most of the exhaust studs do. If I can get a few to line up then it will do the job for what I'm after.
all bar 4 of the studs line up between rb20 and 26 on the inlet and i think similar on the exhaust
i also have rear half of r33 tail shaft
and i have a rb25det head that is only any good as a paper weight so you can get the whole lot off me if you want.
if you need the yoke for the gearbox i have a new one spare
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
