lol, it kept telling me the post didn't work!! I tried it a couple of times with no apparent sucess and went to bed last night thinking it had failed :rant:
I'll give the guy painting the wheels a call Monday or Tuesday, but the 8th could be cutting it fine.
  On 05/10/2011 at 10:56 AM, WHITER33GTS-T said:
Im after another trans cooler or a 25 to 30 row oil cooler that I can run with a fan to keep the auto cool.
Let me know what you have got
This is what you are after Rob. I'd much rather spend a bit more and get a brand new one, that way you know it isn't chockas with shit
http://www.ebay.com.au/itm/B-M-HI-TEK-TRANSMISSION-OIL-FLUID-COOLER-W-ELECTRIC-FAN-/360405477020?pt=Motors_Car_Truck_Parts_Accessories&hash=item53e9d7269c
I'm getting the woman's R33 on the road, I'm after a few random things people might have from popped engines/upgrades?
Stock S1 coil packs (need to be good for 12psi) or cheap after markets
RB20/25/30 Harmonic Balancer w/AC (pref no dents/chips)
Tensioner and Idler pulleys, non rattly (mine were seizing)
The bolt (and if possible 2 washers) that go with the t-belt idler pulley
And just for my R33, a split dump pipe, either just the top/front section or all the way to cat, as I have a stock front pipe with 3" dump and am trying to fix slight over-boosting.
Just PM me! Cheers
-Dan
Just PM me! Cheers
-Dan
i would have a ballancer and im coming down to hobart this weekend if you want it.
  On 03/11/2011 at 10:40 AM, tweetywoof said:
Ok man, i live in lutana but work in kingston so i could meet you pretty much anywhere when you want it!
I think i know where you live. :P
I'm up the road and around the corner i think. :D
The 32 with a carbon bonnet is Xrated i think. I used to drive a blue 31 with s13 wheels. Had a white 31 parked out front for ages. Been stuck driving the shitty VN wagon, the D21 Navara and the missus 04 Corolla. Soon i'll be getting about in my Black over grey 31 Coupe though.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
