anyone got some r33 gts rotors going cheap?
i've got some of the same size but they are 5 stud, so if you want to sell me your 33 gts rotors and they are in decent nick and cheap then i shall take them off your hands
I've got a pair here but they will most likely need machining as they've got a small lip on the outside edge
Have heaps more stuff than listed :)
Dave - 0409 631 092
Just a few things to get out of my shed, as usual have run out of space!
20V AE86 $6500 http://burnie-devonp...?AdId=360168336
1JZ S14 $18000 http://www.nissansil...em&item_id=4397
1JZ S13 $11000 http://burnie-devonp...?AdId=352702689
Rims for sale!
Work Meister S1 3 Piece 18x9.5 -3 pair $1600
Performance superlights, brand new pair with brand new Hiro Tyres 15x8-4 $600
14x7 ma61 pair with new tyres $250
15x8-10 performance challenger pair with 80% tyres $400
Cooling Shelf overflowing, gotta go!
AE86 52mm twin core alloy radiator new $220
RB20 52mm twin core alloy radiator new $220
Sr20 twin core custom alloy radiator, used $120
SR20 modifed Falcon Thermo Fans, as new $150
SR20, RB20, CA18 stock radiators $50 each
Used 600x300x60 intercooler $100
Earls Oil Cooler, -10 fittings, new in box, size of a4 page $400 (can do lines also)
Heaps more than I can think of at the moment, ask away!
Engines/Gearboxes/Mount Kits in stock, all great condition as usual
1jz manual package $3500
SR20 manual package (BYO TURBO) $2300
CA18 manual package
LS1 Silvia/Skyline/Cefiro Conversion Kit $2200
1JZ Silvia Mount Kits - $350
S13 Manual Conversion Kits $500
SR20 Gearboxes $500
Quick 180SX body sale need shed space again!
S13 or 180sx complete front conversion kit to S15 - $1100
180SX rear guards 25/30mm Origin Style good condition - $150
180SX Type X front bumpers - $250 each
180sx frp 50mm Origin slightly cracked wide rear guards - $50
180sx frp 40mm Origin front guards, drilled frr cable tie bumper mounts - $200
180sx standard tail light set (not type x) $150
Federal rsr semi slicks 70% 215/40/17 $250 pair
Federal rsr semi slicks brand new 215/40/17 $400 pair
Federal 595ss brand new 215 and 235/45/17 $250 pair
Federal 595ss brand new 235/40/18 $275 pair
Federal EVO brand new 195/50/15 $220 pair
And any other federal or kumho or no name cheapies also available too much to list of course :)
Dave - 0409 631 092
Edited by Dave.TAS
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
