I much prefer the D-jetro option, speak to your tuner though they should have a preference...
Cheers matey im seriously considering going this route and being done with it but my tuner has said that the car will be alot smoother and nicer to drive with normal power fc and afm's as opposed to d-jetro and a map sensor.. How do you find the d-jetro when your holding a certain speed on freeway and when your on off the throttle in traffic etc?
https://www.sau.com.au/forums/topic/363731-rb26-to4z-setup/#findComment-5804279
That sounds like your tuner doesnt know how to tune d-jetro properly, so if you stay with that tuner, use afms.
https://www.sau.com.au/forums/topic/363731-rb26-to4z-setup/#findComment-5804324
Did you get any problems with the Afm's voltage spiking to much under light on/off throttle causing the car to stutter or hesitate and sometimes cause it to stall?
this only occurs if the AFM are too close to the inlet, and reverberation etc.
if its spaced as far as possible, these issues seem not to occur
https://www.sau.com.au/forums/topic/363731-rb26-to4z-setup/#findComment-5804406
agree, djetro and ljetro (ref DVS32R)
both are the same to tune and setup, and i think from memory the djetro takes longer as you have to work so much harder at the transient throttle process more to get it nice, vs AFM that is bulletproof on the factory maps on the powerfc, ie you dont have to focus so much on that area (from no throttle, to light throttle)
both will make same power and response
but will perform differently as far as mapping and scaling are concerned
but back on topic,
you should not max twin Z32s with T04Z
https://www.sau.com.au/forums/topic/363731-rb26-to4z-setup/#findComment-5804875
This is the log from my 460awkw dyno run. 26psi 2530's
The Z32's have some voltage left but the 800cc injectors are out...
Jebuz! Is that on 98? Do the HKS turbos make more power than the -5s? I thought 400awkw was the limit of 2530/-5s on pump.
https://www.sau.com.au/forums/topic/363731-rb26-to4z-setup/#findComment-5805708
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
