These items are all BRAND NEW and UNUSED
i have 5 meters of -8AN teflon coated stainless steel fuel line for sale (genuine American Dupont)
it is a continuous length of 5 meters UNCUT hard teflon interior
Internal diameter: 10.5mm
Outer diameter: 13.5mm
rated at 2500psi
this fuel line will fit with any skyline coz i bought it to fit my R34GTT Neo
teflon coated fuel lines are perfect for running E85
as you know this stuff is very expensive, i paid a sh*t load of money for it - paid $200 for 5meters
but i bought too many meters so i'm trying to sell whats leftover
PRICE: $150 for 5 meters
no pickup ONLY POST at your cost
i also have the fittings that go with this -8AN fuel line
they are re-useable aluminum swivel fittings
i have 10 red/blue fittings for sale
i paid $10 each
PRICE: $5 EACH
PM me if you are interested
  • 3 months later...
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
