hey all who can help,
ive got a 1996 r33 gts-t series two. i bought it completely stock about a year ago, and im slow trying to make it my new circuit car. ne way i had it dyno'd about a month ago and it seems that im not make anywhere near as much power as i should be. again its pritty much stock. i ran 140.8hp at the rears, ive replaced the fuel pump with a walbro 255, replaced the fuel filter, replaced the fuel pressure reg with a turbosmart fpr 800. new splitfire coilpacks, iridium sparkies. 3" catback exhaust. also replaced the o2 sensor. i thought it might have been a wastegate issue, so i hooked up a boost gauge strait to the intake manifold and its registering 8psi. was thinking a possible restriction right at the throat of the intake to the block so i might replace the the stock intercooler and change the intake to a greddy type. oh and its got a fuel smell from the exhaust.
any help would be appreciated
thanks,
riley
https://www.sau.com.au/forums/topic/363767-r33-series-2-dramas/
Is it stock ecu?
Why did u replace the fp. Reg? Might be making it run evem richer then the stock ecu normally does
What afr is it at on the dyno?
fpr was stuffed the seat for the stock one had cracked, its set to 43 psi which is the stock fuel pressure rating, not sure what u mean by afr
remove the turbosmart FPR get yourself a stock FPR they are good for up to 350rwkw i beleive. thats why you are running rich with a fuel smell.
with the cat just drop down the exhaust and have a look
cheers mate ill give that a go. i thought the rising rate FPR would have done the job as its adjustable and set to nissan specs. wheres the best place to pick one up. having a hard time finding one, hence why i put an aftermarket one on.
compression is at 140 even though all cylinders, sounds a bit low but aparently its fine, any way of checking the cat to see if its clogged or blocked?
Hey isnt that compression a bit off, last time i did mine they were more like 170 give or take 5, maybe its not the problem but that wouldnt be doing things much good would it??? i agree though about the FPR
  • 2 months later...
well i just replaced my turbosmart fpr back to the standard one, it runs a little better but still getting a fuel smell (bad) on start up and idle.
i just bought another rb25det s2 so i can rebuild it while i drive this engine into the ground lol. i plan on building the shit out of it and boring it to a 2.7L (unless someone convinces me other wise)
does any one know where the best place would be to buy a rebuild kit and where to get a head gasket to suit a 2.7L?
It is almost certainly the tune, stock tune when running more boost sucks ass, rich and very retarded.
Get a proper intercooler, straight through 3" with a decent muffler, new coils and plugs and nistune it and get a reputable tuner to tune it. Should see 180-190kw fairly easily. Stock it can be as low as 120kw due to there being no timing and it running rich as hell.
Replace the FPR with a stock regulator, no need for the aftermarket one, often less reliable than stock and it is just one more thing to get defected for.
The compression test is fine as long as there is no more than a variance of ~5 or so between cylinders. Mine read 110 when I did it and still made healthy power.
Don't waste your money building it to 2.7L (how?), do a 3L conversion if you absolutely must. The 2.5L is capable of 280-300kw without a rebuild and not much lag, this is more than you need for most circuit cars anyway. Save your cash and get a highflow turbo, Z32 air filter and some bigger injectors, cost you maybe $5k in supporting mods and it will make 250-300kw depending on turbo choice. This is the smartest decision financially, an even smarter decision is sell the car and buy one with your desired power level already that someone else has already tipped all their cash into.
any idea on how to adjust it and check it?
Aftermarket ECU or nistune (highly recommended do a search) and pay a tuner to tune it for your mods, you can't just change stuff and expect it to run right, needs to be retuned for it to run properly.
Edited by Rolls
ya someone literally just told me it could be an ecu problem.
as for the 2.7 one of my bosses did it to his and recommended i should do that or a rb30, i originally wanted to put a 26 in in it but he told $$$$$$$$$ to me lol
i just moved to darwin so i dont know of any decent tuners in the area. ive already got a walbro 255 fuel pump, a 3" cat back, splitfire coilpacks and iridium sparkplugs and i just changed the turbosmart fpr back to the standard reg.
as it is my only car the idea of building a seperate engine seems like a good way to continue to drive my car untill its ready to go in. im not sure how u go about building a rb27 but ill definatly look into it. if its to much of a stuff around ill just do a 30/25. i just want to do something everyone hasn't already done.
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
