It isn't so much as a problem as what nissan designed the ECU to do. Basically they made the upper right quadrant of the map very rich in fuel and low on timing, this was so if some average joe upped the boost and went around flogging the motor it didn't blow up. Basically an extra safety factor, all you need is a tuner to remap this part of the map with more sane fuel and ignition values, obviously making sure the engine is in good condition first (clean injectors, good pump etc). Standard ECU isn't easily remappable, if you get a nistune daughterboard plugged in it allows real time tuning like on a full aftermarket ECU, highly recommended.
Building a motor, rb20, rb25, rb27, rb30 etc is all the same, just different crank/rods/pistons depending on the combo so if you are going to build a motor build a 30 as it wins hands down.
HOWEVER you want a circuit car yes? 300kw is OODLES of power for a circuit car, also with 2.5L 300kw can be had without too much lag making it very nice to drive still, also 300kw isn't unachievable for a stock engine, it will put up with this sort of abuse for a long time if careful and meticulously tuned.
So bang for buck, get a highflow suitable for 250-300kw (check out the hypergear thread), z32 air flow meter, metal intake pipe, intercooler, bigger injectors, and a nistune computer, all the supporting mods (and get it tuned lol). All the supporting mods to handle 250-300kw reliably on the track will set you back $5k (clutch, tyres suspension, diff etc) this is your best option by far, you have a spare rb25 if it blows up. If you stick with 250kw you will have a very fast car still and it will probably last a very long time if you get it tuned correctly. Getting it tuned correctly is VERY important, this is the difference between a car that lasts 3 months and one that lasts 3 years, do not skimp on tuning and do not skimp on a tuner.
If you go and build a motor, there goes $5k minimum and you haven't got ANY of the supporting mods, what use is a built motor with stock turbo and intercooler etc? Especially if you can't afford the $1k for semi slicks on the track, complete waste. Do not do this unless you are willing to spend $10k minimum to do everything that goes along with the motor, in the end you won't have a faster car anyway, 300kw is probably the limit unless you are a pro driver, especially with the suspension setup you will probably use.
So my advice don't touch the motor and do all the supporting mods and enjoy. Also don't forget if you build a motor you will be needing to spend at least $1k getting it tuned, I don't think you realise how expensive this will all get, at least $10k to get it all going, probably more once you fix all the stuff that breaks along the way.
My ultimate advice is sell the car and buy a mint 300kw example with everything already done, built motor the works. Your R33 is probably worth what $9k? Sell it for that, add on your $5k and you can get a $14k car, there are lots of 250-300kw R33s (r32s as well) for this price with all the mods you want and in very nice condition all ready to go.
Think LONG and HARD before considering building an engine, you will almost certainly regret it if $5k is your limit.
i just want to do something everyone hasn't already done.
No offense but people say this all the time and go and build stupid engines like an rb24 etc, it costs them a shitload and in the end someone who has spent a couple of grand on a highflow on their stock rb25 beats it in every single way. You drive a skyline, nothing you do will be original, plus when you go to the track they won't go 'wow thats an rb24 when you drive past' they will go 'wow he isn't as fast as that other car!'. Being different for the sake of it is stupid, being different because you found a better way is what you should do, however everyone has already figured out the best way to do things. Bang for buck, this is the philosophy you should be using!
Edited by Rolls
im just gunna go ahead and add u cause ur pritty switched on mate :O.lol
ive done quite a bit of racing in canada (not drifting) so im familiar with racing and i know the cost. i get what ur saying about buying a already done car. but theres no fun in driving something someone else has built. its like u buying a car dumping ur life savings in it making the fastest thing on the road, and not drive it cause u have no licence. ive always had fast cars but some one else has done all the work ive just forked out the money. this one is different. i want to build as much as i can(if i have the equipment to do so.
ill prolly just keep the 25 then and just change the the internals to forged (without stingeing on a proper tune of course :thumbsup:) would u recommend a z32 afm or eleminate it completely with a power fc?
thanks for the advice ill be in touch
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
