Silvia S15's cam in base models and Autech models.
Spec S came with 5 speed manuals or 4 speed Autos.
Spec R came in 6 speed manuals and I think Auto as well but ADM.
Autech models I heard come in both, manual and auto.
https://www.sau.com.au/forums/topic/363813-autech/#findComment-5806257
Is there a model thats NA and not autech? Like just a sr20
LOl, No, I am talking about a hardtop s15 pretty much like the autech version, without the autech if you get that?
Yes, in Japan, they were the Spec-S'.
Almost, Were the cars Autech tuned made especially for them for that reason? If not were there detuned versions for sale for say a NA s15 silvia
The Varietta was built by Autech and based on the Spec-S model.
Powered by a SR20DE (N/A, same as the Spec-S in Japan) and with a choice of the 4-speed automatic or the 5-speed manual.
Was released with a retractable hard top.
Autech specifically tune Nissan cars.
It was founded in 1986 as a subsidiary of Nissan.
They also tune the engines for the Nismo R34 GTR and 350Z JGTC GT500 cars.
https://www.sau.com.au/forums/topic/363813-autech/#findComment-5807141
Ok So s15's sold in Australia spec S and spec R were both sr20det, while the s15 spec S in japan was NA and the spec R -det.
Edit: Just read somewhere else that jap s15 spec S sr20de isn't allowed to be imported, Would that still qualify for sevs import or just not at all?
Edited by hooon
https://www.sau.com.au/forums/topic/363813-autech/#findComment-5807239
I believe so.
You will have check with the Car Importing business.
ie, go and ask an import dealer or PM Iron Chef or Carizma International on here (SAU).
If they cannot not be imported, they might explain why both of the ADM S15 Spec - S and Spec - R's are turbo.
The local Nissan dealer must did a bit of a marketing and took Spec - R's, badge them as Spec-S', removed add on parts like the spoiler and sold them cheaper.
They imported the Spec - R sold them for more and would have had all the add on parts.
Then the Spec - R GT came out.
Spec - R GT = Spec - R but with a larger rear spoiler and shiny metal add on parts and I think leather seats.
Mostly cosmetic changes I think.
https://www.sau.com.au/forums/topic/363813-autech/#findComment-5807893
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
    • But I think you missed mine.. there is also nothing about the 98 spec that supports your claim..  according to the fuel standards, it can be identical to 95, just very slightly higher octane number. But the ulp vs pulp fuel regulations go show 95 (or 98), is not just 91 with some additives. any claim of ‘refined by the better refineries’ or ‘higher quality fuel’ is just hearsay.  I have never seen anything to back up such claims other than ‘my mate used to work for a fuel station’, or ‘drove a fuel delivery truck’, or ‘my mechanic says’.. the actual energy densities do slightly vary between the 3 grades of fuel, but the difference is very minor. That said, I am very happy to be proven wrong if anyone has some hard evidence..
