The first reply to the thread nailed it. Marc's post there has some pretty good information too.
It all depends on what you're aiming for. You set a goal, then you change all the variables to shoot for that goal. If I want to drag people to 100km/h I'll use the standard 4.11 diff in my Skyline because 2nd gear tops out around that and if it was any shorter I'd need another gear change, which will cost me time. If we're dragging to 80km/h I'll put a 4.36 in the car, because even though 2nd gear will now top out around 90-95, I only need 80 of that and the shorter ratio will give slightly better acceleration.
If you calculate it, a standard R33 GTS-T has the gearing to achieve ~277km/h (forget the exact figure). Realistically you'll only get to around 250 because you'll run out of torque. Shorten the diff a bit and you might get 255 thanks to the extra torque of the gearing. Shorten it too much and you'll only get 230 because your car will redline in top gear at this speed. Make it too tall (say 2.5:1) and you'll have a theoretical top speed of 400km/h+ with only enough torque to get to 160-170. But 1000hp behind that ratio and you'll propel the car to around 320. There are lots of variables to it all.
All hypotheticals for the purpose of examples^
Actually there arent alot of variables. It is pretty simple.
You have two factors.
1. How many horsepowers your car can produce at a given speed.
2. How much drag you car generates at a given speed.
When these are equal you are going as fast as you can.
The gearing dictates where abouts on the powah curve the engine is running - hence it influences the top speed. Excessively tall gearing means you dont make all the hp you can and you are therefore slower than may otherwise be possible. Too short on the gearing & you have introduced a new, mechanical limit to things.
To go twice as fast you need eight times as much power. Yes, boys and girls, eight times. It is a cubic relationship.
lol, way to over-simplify it by stating umbrella variables. I can do that too, watch:
There's actually only one variable to it - how fast your car can go!
Or we can just not play devils advocate for the sake of it...
Reality: there are tons of underlying variables that influence factors such as drag, gearing, torque etc.
Be careful with loading up 5th gear at low speeds, because it is an overdrive gear and you will now have increased resistance from the taller ratio. The standard ratios are pretty well setup so that the engine and gearbox are never laboured, so just make sure you're staying within a healthy torque band :)
If this was for me, dont worry mate I only have 3 gears :whistling:
yes definatly one of your better posts Marc. While i have your attention, do bike speedos work in cars?
short answer: no. long answer: no they won't.
Im changing from a 4.1 to a 3.7 in my 33 for more top end and less revs on highway at 110kph
skylines are a small displacement engine, so they won't handle the taller diff ratio as well as a big cube engine. you may find that a smaller hill on the highway may require you to change down a gear as it is putting you into a lower torque range and taking you into an area of the rev range where you might not be making full boost. it will also make the car harder to get off the line (including reversing), so you will see increased clutch wear as possibly worse fuel economy. also as for gaining "more top end", unless you were pushing serious horsepower (enough to max out 5th gear, so up around 350 to 400kw at the wheels) you will lose top end and have a lower top speed than with the stock gearing.
EDIT: just saw you are running a C4, so you would be maxing out top gear pretty easily, so you can disregard my post, but it still is worth posting for other people thinking of changing diff ratios with the stock 5sp gearbox.
Im running a tricked up C4 but would still like to use a 5 speed again one day. I think the extra torque from a 3lt would still be fine with a taller diff but my turbo would be a little laggy. lol
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
