Hi guys, I'm selling my Brand New HKS 3037 turbo kit which has only been on my R33 for 3 weeks.. It has an RB25 rear
housing bored out to .72 & comes with all new lines and fittings to suit RB25 aswell as the custom 3.5" intake
made for it. This turbo is fantastic for the street. Very, very alive at low RPM and produces great torque.
Car starts to pull aggressively from 3500rpm. Made 280rwkw on just 18psi with standard Cams running a Haltech.
Item: HKS/Garrett 3037 Turbo Kit, suit RB25
Condition: Like new, only 3 Weeks old
Price: $2,100ono
Reason for sale: Change of plans with my engine
Contact: Dean - 0401 682 270
Pictures: MSG me on the above number
Edited by Dean_HR31
https://www.sau.com.au/forums/topic/363836-hks-3037-turbo-kit-3-weeks-old/
The turbo has a '3037' stamp on it which makes it a HKS from what I've been told. I am basically using the info I was told by the guy i bought it off a month ago. The Turbo was brand new and never fitted. It has been fitted to my track car for 3 weeks and possible driven a maximum of 500kms...
Whoever is keen on the turbo can simply leave a deposit and I will have it removed.
Am willing to swap for a Garret 3540 as this is my track car and dont exactly need anything response like this.
A few more pics attached. I will have a pic of the ID tag tonight confirming its a 3037.
As I said, I bought this turbo privately from a guy who never ended up fitting it to his car, so the way it is, is the way I got it. I will contact the previous owner today and find out about the rear housing.
Feel free to ask any further questions.
my garrett gt3076r has 3037 on the tag, because they use a 3037 core.
but that does look like a garrett with the rb25 rear housing option.
so yes garrett not hks...
otheriwse the rear housing would have hks stamped on it.
sorry its not a hks pro s as i have one a few different things is rear housing size,dump pipe needed is different,surge cover over cold side.
sorry
Edited by WARLORD
  • 3 weeks later...
  • 3 months later...
Guys price is negotiable, make me an offer. I Just got back from overseas and need to sell this ASAP. As my 33 is now a track car only, I want an externally gated turbo. This is the only reason why im selling it. Therefore, I'm open to swaps for an externally gated turbo in equal new condition as mine.
  • 3 weeks later...
dont mean to hijack your thread but genuine complete garrett 3076 with all housings optional are only 1550 brand new delivered from street to track and a few other garrett suppliers here in aus with warranty and all
If your not interested simply don't reply. People can do there own research if they want the turbo or not.
Hi mate, yes I do have a Dyno sheet. I will try find it tonight and scan it. Alternatively you could give Chasers Motorworks a call on 9687 7118 and ask them about my Red R33.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
