Hey guy did some research and couldn't find an answer to my thoughts. Thinking of upgrading my brakes, i've found some brake calipers 6 pot, and 355mm rotors, but the kit is for a bmw.
Question is will it fit the 33 gtr providing I get a custom bracket made for it? Is there anything else i'd have to change?
Sorry for the newbiness.
-thanks.
https://www.sau.com.au/forums/topic/363867-gtr-brake-upgrade/
I've just put on some K-sport 8 pot 356mm 32mm on the front will be testing at the track this weekend, but they feel great and are quite a bit bigger than the Brembos that came off ( which I will sell SiR RB , pm me ) good up grade for around $2400rrp but I think there might be a Group buy in the pipe line, keep an eye out ..
The main thing you have to remember with brake upgrades that 50% of people know very little about is brake bias.
Your car from factory has a certain amount of brake force sent to the front and sent to the rear. If you then suddenly throw a set of brakes on the front or on the rear that throws this balance out way to much you will have problems.
So while that kit for the BMW may fit your car with a custom adaptor, what is the actual specs on the caliper? What is the total surface area of the pistons? There is a lot to it and a lot of good information on the forums so have a bit of a search and a read. I learnt a lot from organing the Wilwood group buy and even though a brake setup might look good in a photo doesn't mean it will suit your vehicle and needs.
yeah it's not as simple as 'yes it'll fit with adapter'. what offset, bore and PCD are the rotors? if they are not the same as your hub and caliper offset then you're screwed (though you can offset the caliper to some extent). Also, is the caliper radial mount or lug mount? if it's lug mount it might not be possible to mount it. radial mount will be better and easier but again you need to work with the rotor offset and get the caliper mounted properly. it's not something you can just guess or do 'by eye'. if it's not perfect things will go wrong.
There are literally dozens of brake upgrade options made just for GTRs. why not buy one?
of the top of my head I can think of 5 companies that do F40 and F50 brembo upgrades with 324mm, 330mmm, 355mm or 370mm rotors. There are 2 or 3 options from stoptech. There are big brembo 6 and 8 pot kits again from 355mm up to 380mm rotors, there are K-sport, bok-choy, D2, JJR and whatever other name they are stamping this week onto cheap chinese/taiwanese brake kits again with anything from 324mm up to 355mm+. Then there are Trust kits both with trust branded calipers and alcon calipers, there are endless kits of about 4 different types with various caliper and rotor choices, there are project Mu kits again in many types, there are half a dozen different AP racing kits (at least) and a number of options from Alcon too.
All of which come with the right offset rotors, the right size and length lines, the right caliper mounts, pads and are sized correctly for your car. why buy a kit for another model car? it's a false economy.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
