I have a plazmaman plenum on my RB20 and the results were a bit disappointing. I simply have not been able tonmatch the std plenums performance let alone realise a gain
I was thinking on the weekend, we have not played with the cam gears from when it was tuned with the std plenum. I still have std cams. Do you have to change the cam gear settings with a plenum, or do people typically still run 0 on inlet and retard about 4 deg on exhaust?
https://www.sau.com.au/forums/topic/363871-tuning-with-aftermaeket-plenums/
So what are your cams degreed at currently? ie. does it have adjustable gears
Also did you expect a performance gain in some way, or accept it as a cosmetic tart up or a means of easier access to injectors, shorter pipework etc?
That aside, I wouldn't think you'd necessarily end up with lower outputs.
Edited by Dale FZ1
Runner lenght is what its about, apparently, been told that my runners on my GREEDY (china spec) plenum are not as long as the tuner would like and I would make better power/response with my old standard RB25 one.
This is info that I gleened whilst listenening to my tuner going on about velocity and power and stuff which I didnt really understand but it sounded like tech secret stuff about stuff.
Makes sense though as the same issues with runner lenght on exhaust manifolds are used for moving the power and tourqe around, or something like that, LOL.
I'm not surprised to be honest. much shorter runnes. usually when going shorter runners the diameter is increased to aid top end. but in the plazmaman set-up you retain half the standard runners so you now have shorter runners (less midrange) and no diameter increase (no top end benefit either). so it's kind of the worst of both worlds. the only advantage is the simple pipework and easy access etc but I thought your old set-up was money anyway.
by all means try the cam gear tuning. there's no doubt the plenum has changed the power curve and tuning with the cam gears may have some benefit again.
My cam gears are 0 on inlet and retard about 4 deg on exhaust.
As you can see its slower to ramp onto boost, loses a fair bit in the midrange...but holds on top a bit better. It also seems to take less ignition then the std plenum.
Based on what other people have quoted on pages of this forum, i didnt really expect to make more power, or care to make more power. The talk is I could expect 200rpm or so increased response, which I was hoping to get another 15rwkws or so 4,500rpm to help with 3rd gear corner exits at the circuit where at present I just have to wait a tad to get onto power band. You can see from about 1:12 to 2.00 that there are 3rd gear corners where I just need a little more jump out of the corners. ...http://www.youtube.com/watch?v=gOl-IGx8UkQ ... (especially at 1.39 and 1:50)
I understand all the fluids of inlet manifolds reasonably well. But with so many people say raving about their performance increase, some even say same power at less boost...I thought I would give it a go. But much like my change from a Greddy exhaust manifold to a 6boost manifold did nothing to improve performance (most things point at I lost a little bit of response) it seems that I can get the same performance increase with the plenum as others.
So, before throwing another $200-350 at the tuner to try different cam gear settings, thought I would post up to see if any oen has tried a Greddy plenum, plazmaman plenum or other which has meant the proven I=0, E=-4 deg recipe for cam gears is different with an aftermarket plenum.
Bris - I know this isnt really related to cam gears, and it costs money.
But have you thought about pulling the head off and having the ports tickled?
Wouldnt need much, and I wouldn't go any larger in port volume, but I have no doubt there are REAL gains to be had with a bit of a grind, espesially on the exhaust side of the 20 Head.
I would leave the standard cams as you are making power right through to the rev-cut, so unless you want another 1000rpm on top (which the 20g won't allow) I would definately leave the standard bump sticks, and as you found the the Apexi (I think) cams you went backwards.
If you do want cams + more mid range, have a look at getting some custom cams ground, with a smidge more lift and LESS duration than standard.
Anyhoo, hope you get it sorted :)
Andrew
Quick Edit -
Bris, That little RB20 is making something like 210-220hp/L
Pretty good when you think of it like that.
when i went from standard plenum to greddy copy plemum i lost a little in midrange but gained an extra 10 rwhp. Response was almost identicle .This was with stock turbo, front mount ic,3inch exhaust ,power fc etc.
LOL, had never even stopped to consider that. Not bad for a std motor I suppose:)
Re head work. I may pick up a std head and give it a go myself. But honestly, by the time i buy new head gasket, head bolts, new timign belt, coolant, sump of oil etc even trying to do a head clean up on the cheap will cost $500-800. :(
Will try some headwork if nobody buys my Tomei 2.4L gear soon as the combustion chamber needs to be opened up to suit the bigger bore :) And re cams, I have something sorted since i have Tomei solid lifters and Tomei valve springs to suit :) But dont want to spend any money really, the power is enough, just trying to see what i can do to get the most out of std 20. I understand some of the myths out there about parts, thought these two parts were going to work for me. So far doing accurate back to back the 6boost has been nothing but a backwards step as it cost me money, the Turbosmart gate doesnt sound as good as the Greddy gate ( :) ) and and didnt deliver any performance increase over the Greddy manifold. It may prove to last longer though. And the Plazmaman, well ... yeh well. Seems to work on some other setups, just not mine :)
I reckon flog the 6boost mani (should be easy, plenty of market for them), flog the turbosmart gate. refit the trust mani and trust gate (both of which worked perfectly with teh trust turbs). then look at going back to a stock plenum. for response it will be hard to beat. and it did sound pretty sexual too.
as far as going cams to get response I don't reckon it'll work. cam gear tuning yeah, but new cams I think will only shift the powerband higher again unless you stick with the same or less duration which I think is probably a waste of time too.
cam gear tuning might help solve the current deficiency.
try winding some inlet advance into it, say +2. From memory the RB20 has 7deg overlap, your settings bring that down to 3 deg. But every engine is diferent, and ther is no set standard....bla bla bla
I'll be trying some diferent cam on mine in the near future.
Thats only if you overcam it for the setup, most "street" Kelfords boost midrange and top end with no noticeable loss of downlow. I think the Plazmaman manifolds seem to rely on big bites of air being taken by the engine, even stock RB25/Rb26s loose some in the lower flow areas with these kinds of manifolds. Is the volume/runner size the same for the RB20s as the RB25/26s?
I'd consider using a manifold like what RIPS make which use the stock runners but with a bigger plenum volume to try and drag things back into parity with the standard "bites". I wouldn't have thought the 6boost manifold would cost anything in response, I know of people who have gone GReddy to 6boost and gained everywhere.
Thats my feeling anyway, could be complete BS - but unless I was intending on building an RB20 to rev way beyond the normal RPM range I'd centre my attention on the mid/top end area.
+1 :D
I'd say that your particular setup is a different combination to others, so it may prove that the only test is to plump for an hour or two of dyno time to prove it. Mind you, it is pretty simple to at least road test the difference between current, and then advance the inlet a couple of degrees. It will probably be noticeable, as I found while trialing my own setup.
So far doing accurate back to back the 6boost has been nothing but a backwards step ... and didnt deliver any performance increase over the Greddy manifold. It may prove to last longer though. And the Plazmaman, well ... yeh well. Seems to work on some other setups, just not mine :)
I'd tend to agree that a cleanup of the ports will help, but again cost is the factor. A bit hard to justify the cost for something that may give you 10hp - chasing diminishing returns. Different if the engine is apart and you've got the time and tools.
Seems that the trapping efficiency in the chambers is different with this particular inlet/exhaust/turbine combination and it just needs time and a capped amount of $$ spent establishing what it likes for cam timing.
Where exactly was the ignition timing wound back, and why? Did the thing knock? A couple of degrees taken out will easily cost you the loss shown on overlay.
Side issue; I much prefer to look at the torque curves, makes much more sense and in my view magnifies the differences between runs.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
