Hey,
Just wondering whether anyone ever dabbled in Draw-through carb turbo setups?
Its for a little project of mine.
its a Mitsubishi and we shall call him....Roger. :whistling:
Basically its a 1.6L OHC carb engine, and for a laugh id like to whack a little turbo on.
So if you have done a draw through setup before, What carb did you use, did you run an Intercooler and how did it go?
Cheers
Andrew
https://www.sau.com.au/forums/topic/363971-hey-old-guys/
i was going to run a turbo on a carby motor in a gemini once from all the research i did no one seemed to run a cooler however i cant see why it cant be done. but depends on the boost level
http://turbogemini.com/Blow%20Through%20Carby%20Kit.htm
thats the kit i was looking at for the gemini i know its a different motor but it would be same setup
https://www.sau.com.au/forums/topic/363971-hey-old-guys/#findComment-5808022
Blow though setups are too hard to tune, and the boost pressure tends to blow out seals and the carbs.
hence going a draw though setup, where the carb works as normal (under vacuum)
Water to air still would have the same issue of having fuel pool inside the core.
https://www.sau.com.au/forums/topic/363971-hey-old-guys/#findComment-5808051
but how? would the fuel only spill/seep back due to the design of the pipe(ie levels angles)
or does it somewhat splash back??
i'de be going superCharge but for benefit of this thread i would like to see the outcome of a Tcharged draw through carby(if it would work)
https://www.sau.com.au/forums/topic/363971-hey-old-guys/#findComment-5808053
It probably wont go bang but fuel pooling in the core is a pain.
On a draw through set up the need for an IC is less because you have the fuel absorbing some of the heat as the air is compressed. So your intake temps arnt as hot.
If you run a blow through set up on low boost, most carbs will take it. You might see 30-50% more power on 5-7psi
Any more then that carbs will start to leak and ignition timing is a problem
Running around in old shitters with a turbo is fun tho
If its an old galant/lancer? Tho you might have more fun and easier time putting a 2.6 in it. from what I recall they bolt straight in- just make up a tailshaft
https://www.sau.com.au/forums/topic/363971-hey-old-guys/#findComment-5808057
Its a cordia.
So there is the factory turbo 4g62 motor, but I wanna do something a bit different and I also cbf swapping motors and looms and all that crap.
The supercharger idea sounds pretty good too.
i reckon having some sort of catch can would help.
i know its not a carby but with our cars some of em have had a catch can installed for the intake side to get all the water condesation away from the FMIC it mainly for cold starts. Idea??
https://www.sau.com.au/forums/topic/363971-hey-old-guys/#findComment-5808073
Turbocharged carby motors confuzzle me... Like if you are using a draw-through setup, how does the turbo go having to compress fuel as well? Would the fuel not have a tendency to pool everywhere, regardless of if you have an intercooler or not? And is it not rather counterproductive having the carby creating a pressure drop and then the turbo trying to increase the pressure? And if you are using a blow-through setup (mute point in your case, but thought I'd bring it up anyway), wouldn't you be running your engine extremely lean at high boost? Considering carby's would apply the same amount of fuel to 0psi as they would to 10psi?
https://www.sau.com.au/forums/topic/363971-hey-old-guys/#findComment-5808156
wouldn't the fuel going through the turbo and piping cool it a little bit any way?
Are you worried that a IC would cause the fuel to cool too much and drop out of the air? I've of heard that being a problem with (v8) cars with long runners and bonnet scoops cooling the runners which makes the fuel drop out of the air.
Mitsi Cordial with a carby and a turbo it's going to make huge power no matter what you do so I wouldn't bother with an IC. It's still going to be a hoot! :P Just get a top mount turbo that plugs almost straight into the TB :D
https://www.sau.com.au/forums/topic/363971-hey-old-guys/#findComment-5808161
You use a rising rate pressure reg to keep the fuel pressure up to the carb.
The turbos dont mind the fuel, same as a WMI setup really.
https://www.sau.com.au/forums/topic/363971-hey-old-guys/#findComment-5808163
if your doing a cordia get the 4g4 engine , its a 2.4 and it comes out in fwd configuration.
will certainly help wake up the cordia, actually it will more than likely tear out the front of the car with the weakened cordia from all the rust they were famous for
https://www.sau.com.au/forums/topic/363971-hey-old-guys/#findComment-5808166
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
