In draw through you can run what ever you want. Just need to size it correctly and play with the jets.
The limitation will be what carb you can get cheap and what adapters you can find/bodge together for cheap.
A single side draught weber will work, ditto dellortos or any other side draught type carb.
I think the old Werritt special sigma turbos ran a single 1.5SU. Those kits pop up occasionally for cheap.
I've seen holleys used but it's ugly as the carb is designed to sit flat so you need this 90 degree bend/adapter thing. Plus the holley premium...
I reckon it'd be cheaper trying to find an old analogue microtech fuel only comp (ah the memories) and run the original injectors.
Emanage blue running 2 1000cc injectors? Cheap as chips. :)
This ..
probably wouldnt cost much more than a webber would anyway
This,
wouldnt work, as i'd need a factory ECU to run the Emanage off
Lol yeah Matty, toying with some ideas
Had a quick flick through, but has anyone suggested "boxing" the carby?
For terms of simplicity and dirt cheap cost, you could run a smallish single injector that comes on with boost, rigged up to the distributor for switching/duration to match the engine speed, but obviously will require a high pressure pump and some electronics....
Not room to box the carb, and doing that still never works quite right, because the Carb then has no laminar airflow running through the ventruies, as its basically just stagnant air.
Also doesnt solve the issue of the boost pressure forcing fuel back through the metering blocks and into the bowls.
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
