  • 9 months later...
So I participated in the 12km run for the Perth City to Surf yesterday.
I ran the whole way, with a time of 1 hour and 10 minutes.
Out of 11,173 people for my particular event, overall I came 4604, my gender place was 1321, and for my category of female 30-39 years I came 388th
Not bad for my first ever time at running 12km!
https://www.sau.com.au/forums/topic/363972-running/page/10/#findComment-7379257
Well done, running just under 6 min/km. how often do you run? Most people struggle with anything 6min/km over that distance.
I only just broke past the 5 min/km last week and I usually run twice a week. Although I don't run 12 km often.
  • Like 1
https://www.sau.com.au/forums/topic/363972-running/page/10/#findComment-7382800
Thank you :) I don't run anymore. I used to run 5km a few times a week a couple of years ago, but was told it would interfere with my lifting so stopped. I began running a month ago for this City to Surf, didn't run over 8km when training.
I think I have a natural long distance running ability, as I used to win cross country and the 1500m easily at school.
https://www.sau.com.au/forums/topic/363972-running/page/10/#findComment-7383100
Natural Ability or not, It's surprising how quickly the body adapts to running if your willing to put in regular efforts and push yourself through the pain barrier :D
I wanted to improve my running and lose a bit of body fat to get ready for a fitness course so I added a 4 km run to my program a couple of times a week for a few weeks.
My times went from
Run times
16:09 to 15:28.. Would probably be a bit faster then that now
This was on a street course.. Running up hills makes a big difference as well
https://www.sau.com.au/forums/topic/363972-running/page/10/#findComment-7383489
  • 3 months later...
My times went from
Run times
Hadn't done this run for a few months now..
Managed a 15:08.. No idea how that happened as training has not been anywhere near ideal
https://www.sau.com.au/forums/topic/363972-running/page/10/#findComment-7443881
That happened to me on my run...the best time I ever set for my 3km suburban was 11:45, after not having run it for months, and previous pb was 11:59.
Maybe running takes a long time to recover from lol
Love to give it a crack these days because I haven't done it for over a year and my leg strength is significantly different from then
https://www.sau.com.au/forums/topic/363972-running/page/10/#findComment-7443892
  • 5 months later...
What's the deal with compression/recovery tights? Apart from looking like a complete muppet. The ASC website has a few articles, some proving a cardiovascular benefit, and others saying they are a complete waste. Unlike a certain other thread, I am pretty sceptical that these things are worth the money. Or just a big placebo effect.
https://www.sau.com.au/forums/topic/363972-running/page/10/#findComment-7543530
Think you have to ask yourself: regardless of research and benefits, what can this product actually offer you and is it significant? What is missing from you now that you're not getting from your current clothes?
Do you need said cardiovascular benefit? Are you an elite runner chasing that .1% edge on the competition or do you have more to gain by mentally pushing yourself harder alone / adopting performance increases that don't cost you money.
I apply similar logic to supplements. People buy so much shit - wow, like 8 different supplements - to do all manner of things to their body, the benefits of which they aren't really even sure of...or if they've even been proven to work...and they are nowhere near the level where they should be looking for an edge. When someone weaker than me talks about their psyllium husk and flaxseed oil and BCAAs...I just think wow, what a waste of money; this person hasn't even pushed the limits of what they're capable of without this shit; I'm not even that strong by powerlifter standards and this person is taking all this shit while all I do is supplement protein (if I don't eat enough meat).
So honestly, unless they prevent heart attacks or make you perform significantly better and you're already at your limits, I'd rather you be buying them for the muppet look. And if you tell me it's to stay warmer I will tell you to run harder/faster/further!
https://www.sau.com.au/forums/topic/363972-running/page/10/#findComment-7543570
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
