i was wondering who here plays it?!
for those who dont know what it is, its pretty much a racing game like maxi tune and all those other racing games you would played at the acarde
i think it came out like in 2006 but i kinda just got into the game now, im pretty slow, i know =]
i reckon for those who do we should have like a battle gear show down one day
Edited by Krapfish
https://www.sau.com.au/forums/topic/363983-battle-gear-4-tuned/
Krapfish, that's you playing, isn't it?? You're really a dude, aren't you?
I haven't heard of this one. Does remind me of initial D.
Must be big in Asia if they've made a fourth sequel.
lol bbe, nah im nt a dude i dun hav a 3rd leg
it was pretty big in japan like bak in 2006 ish wen it come out but dang y do australia get it a few yrs lata
n no im nt tha good at it cos ma bf n ma bros alwayz let me lead n then get me bak on the last lap so i end up comin 2nd or last =[
will you go out with me
Can you type properly, such poor etiquette
Yeah I've seen this around before...it's a alright game but I can't justify constantly dropping coins and upgrading a car online..I think the asian aracades in the city has it and I think Playtime at Highpoint has it...
I has a small following here...kinda like the Inital D arcade games
I used to play it regularly at the Russell St arcades, until they took them away :'(
Always drove the R34 GTR Z-tune.
Only places I know that have Battle Gear 4 Tuned.
- Crown Casino (Galactic Circus) - Has 6 speed H pattern shifter with clutch.
- Boxhill Central (one of the arcades on Station St near the corner of Whitehorse Rd) - Has sequential gear shift
- Victoria Gardens Shopping Center, Richmond - Next to the cinemas - Has sequential gear shift
Anyone know of other places that have these machines?
awwww *hugs*
nah the key isnt that bad, most people dont know that you can go online from your pc or phone and do up your car =p
cos like wen you pick the car in the machine its all standed stock,
between they have it at playtime too but some place the machine isnt connected to the net so you cant use the key to play online =[
[quote name=ClutchBurndout-:(' timestamp='1305784329' post='5820893]
Edited by Krapfish
  • 3 years later...
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
