Well, I don't really know much but this is my reasoning for getting bilsteins rather than BC coilovers or tein super streets.
Most coilover units are made with twin tube shocks, "The main drawback of a twin-tube damper is that its damping force is not as sensitive nor as repeatable as a mono-tube."
So apparently monotubes are a superior type of shock absorber to the twin tubes... this was also covered in a number of different threads on these forums
for virtually the same price, you're getting monos instead of twins?
And my final reason is that by doing this I can first purchase shocks, then springs ... lowering my instant cost .. the shocks alone will cost about 1k at the moment, and I can then purchase the 600 dollar springs at a later time leaving my pockets slightly less damaged in the meantime :)
As I said before I'm not the smartest guy around, I dont know much, but from reading the forums most people have said that monos are better shocks.
However, I reckon both are good enough for street use, just dont go crazy on the stiffness unless you're into that sorta thing .. I doubt at a street level there'd be a large amount of difference? The price difference is minimal also ..
Tons of people have sworn by Tein Super streets, BC BR Coilovers, and others have also loved their suspension set ups from sydneykid. In the end I think their all good options, and I was just pointing out another option to converge :)
I think it all comes down to prefernce. I personally didnt like having a set height with normal springs. So once you have them you cant do anything but live with how it sits. Where as with coilovers if you wanna do a track day just jack her up and lower and tweak away, and for day to day driving you can raise it another 10mm or whatever.
To be honest i wasnt that happy with my bilsteins, when i had kyb agx's on my ae86 they were awesome, i reckon they would be a better option then bilsteins, atleast they have adjustability for bump and rebound.
Anyways the wheel specs look spot on though.
  • Replies 111
Bilstiens can be had with circlip style adjustments like mine, I prefer to have my car set up to handle correctly at all times, the only thing I sometimes change is camber if I will be doing alot of street driving on street tyres and not semi slicks, dont be fooled by thinking that lowering your car will make it handle better, to a point it will but past that point your steering geometery will be affected and your handling will suffer.
http://legacygt.com/forums/showthread.php/handling-ride-height-low-too-low-19274.html?amp;
All i can say to add to everyone else's input is that i went is that with my experience i went from Stiffer shocks and lowered springs to coilovers and was amazed by the difference. They feel alot stiffer then what i had but aren't as harsh and seem to absord the road better. If that makes any sence. Also if you have coilovers you can set them at a hight which suits where you drive ie; your driveway. Should you move house and it turns out you have clearance issues, it's easily solved with some minor adjustments. If you have lowered springs, you don't have this freedom. Just another thing to make you decision that little bit harder. haha.
Looking forward to see which way you go.
Cheers
I think I might have to go with the BC BR Coilovers, it's pretty much my only option as I need the adjust-ability.
I have a fairly steep driveway, my parents stock height Camry's exhaust will scrape if not on an angle going down......:laugh:
So I guess I will need it pretty high for now, but later this year when studying full time I will be moving down to Melbourne and living in the City, so I can lower it down then :thumbsup:
Hey buddy,
id agree with johnno and converge ,
I have an r33 gtst and i believe ive got the most aggressive offsets and lowering that i can have,
i got 18#9.5 front and back with 245/45 all round, with tein coilovers all round, which sit just above the tyres
all the arches had to be rolled cost bout $50 an arch and worth it, they stick out being 30 offset and on the front they rub abit with a full lock, but not really on the fenders more on the inside cover if you know what i mean, but quite bearable,
so im guessing that would be same on a 34, or if your really conservative and concerned then go no more than 9inch wide on front,
i got the tein coilovers second hand and work well but bit harsh on aussie roads for $800 front and back, and wheels and tyres for $2000 new
hope that helps some...
OP, try and get some before and after laps at a trackday or something, even try and borrow some other shocks and springs and test them out.
Try asking these guys whats best for your application, http://www.heasmans.com.au/new_site3/main.html
Thanks for the info guys, Will keep you updated :thumbsup:
Will be ordering my wheels soon, but have a dilemma.
Car is white, should I get Gunmetal or Bronze?
Just so happens someone on the forums has a R34 with MGM CR Kai's :laugh:
http://i140.photobucket.com/albums/r25/fragmentedperception/Cars/R34%2025GT/Jay-R34-Lowered-091.jpg
http://www.workwheelsusa.com/media/gallery/10/150_full.JPG
Hey buddy,
not even close to the most agressive specs you can have on a 33
  • 1 month later...
Hey guys,
Small update, ordered some BC BR Coilovers from JustJap yesterday, wheels have arrived and are a good fit!
Might do a Coilover install guide for the R34 as there isn't one (Although it's probably similar to the R33 install), not sure if I will though, as it's my first time and it's gonna take me long enough as it is. :rofl2:
haha awesome. Which wheels did you go with in the end? And i'm guessing you found out which type of coilovers you need? Looking forward to seeing the end result. Oh and i'm also demanding before and after pics for wheels and coilovers. Cheers
Ended up with Silver Koya Drift Teks with some Nitto NT05 rubbers on them, not sure what I think of them yet, maybe because the car is too high atm, will have to wait on the coilovers. :D
I'll be sure to get some pics when it's all done. :thumbsup:
hi here is my car with its new project d wheels they look cool but i think the ride still sits to high IMO.
i already have to get the front guards rolled tomorrow due to them scraping when i hit slight bumps.
what are your guys oppinions looks low enough or lower (back looks really high)?
cheers.
looks really high in this pic.
There's something that just doesn't look right, I get the same feeling with mine.
Seems like it's too high or the wheels are too big, something just looks odd.
Can't quite put my finger on it....
EDIT: Maybe try more low?
Edited by Converge
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
