Well, I don't really know much but this is my reasoning for getting bilsteins rather than BC coilovers or tein super streets.
Most coilover units are made with twin tube shocks, "The main drawback of a twin-tube damper is that its damping force is not as sensitive nor as repeatable as a mono-tube."
So apparently monotubes are a superior type of shock absorber to the twin tubes... this was also covered in a number of different threads on these forums
for virtually the same price, you're getting monos instead of twins?
And my final reason is that by doing this I can first purchase shocks, then springs ... lowering my instant cost .. the shocks alone will cost about 1k at the moment, and I can then purchase the 600 dollar springs at a later time leaving my pockets slightly less damaged in the meantime :)
As I said before I'm not the smartest guy around, I dont know much, but from reading the forums most people have said that monos are better shocks.
However, I reckon both are good enough for street use, just dont go crazy on the stiffness unless you're into that sorta thing .. I doubt at a street level there'd be a large amount of difference? The price difference is minimal also ..
Tons of people have sworn by Tein Super streets, BC BR Coilovers, and others have also loved their suspension set ups from sydneykid. In the end I think their all good options, and I was just pointing out another option to converge :)
I think it all comes down to prefernce. I personally didnt like having a set height with normal springs. So once you have them you cant do anything but live with how it sits. Where as with coilovers if you wanna do a track day just jack her up and lower and tweak away, and for day to day driving you can raise it another 10mm or whatever.
To be honest i wasnt that happy with my bilsteins, when i had kyb agx's on my ae86 they were awesome, i reckon they would be a better option then bilsteins, atleast they have adjustability for bump and rebound.
Anyways the wheel specs look spot on though.
  • Replies 111
Bilstiens can be had with circlip style adjustments like mine, I prefer to have my car set up to handle correctly at all times, the only thing I sometimes change is camber if I will be doing alot of street driving on street tyres and not semi slicks, dont be fooled by thinking that lowering your car will make it handle better, to a point it will but past that point your steering geometery will be affected and your handling will suffer.
http://legacygt.com/forums/showthread.php/handling-ride-height-low-too-low-19274.html?amp;
All i can say to add to everyone else's input is that i went is that with my experience i went from Stiffer shocks and lowered springs to coilovers and was amazed by the difference. They feel alot stiffer then what i had but aren't as harsh and seem to absord the road better. If that makes any sence. Also if you have coilovers you can set them at a hight which suits where you drive ie; your driveway. Should you move house and it turns out you have clearance issues, it's easily solved with some minor adjustments. If you have lowered springs, you don't have this freedom. Just another thing to make you decision that little bit harder. haha.
Looking forward to see which way you go.
Cheers
I think I might have to go with the BC BR Coilovers, it's pretty much my only option as I need the adjust-ability.
I have a fairly steep driveway, my parents stock height Camry's exhaust will scrape if not on an angle going down......:laugh:
So I guess I will need it pretty high for now, but later this year when studying full time I will be moving down to Melbourne and living in the City, so I can lower it down then :thumbsup:
Hey buddy,
id agree with johnno and converge ,
I have an r33 gtst and i believe ive got the most aggressive offsets and lowering that i can have,
i got 18#9.5 front and back with 245/45 all round, with tein coilovers all round, which sit just above the tyres
all the arches had to be rolled cost bout $50 an arch and worth it, they stick out being 30 offset and on the front they rub abit with a full lock, but not really on the fenders more on the inside cover if you know what i mean, but quite bearable,
so im guessing that would be same on a 34, or if your really conservative and concerned then go no more than 9inch wide on front,
i got the tein coilovers second hand and work well but bit harsh on aussie roads for $800 front and back, and wheels and tyres for $2000 new
hope that helps some...
OP, try and get some before and after laps at a trackday or something, even try and borrow some other shocks and springs and test them out.
Try asking these guys whats best for your application, http://www.heasmans.com.au/new_site3/main.html
Thanks for the info guys, Will keep you updated :thumbsup:
Will be ordering my wheels soon, but have a dilemma.
Car is white, should I get Gunmetal or Bronze?
Just so happens someone on the forums has a R34 with MGM CR Kai's :laugh:
http://i140.photobucket.com/albums/r25/fragmentedperception/Cars/R34%2025GT/Jay-R34-Lowered-091.jpg
http://www.workwheelsusa.com/media/gallery/10/150_full.JPG
Hey buddy,
not even close to the most agressive specs you can have on a 33
  • 1 month later...
Hey guys,
Small update, ordered some BC BR Coilovers from JustJap yesterday, wheels have arrived and are a good fit!
Might do a Coilover install guide for the R34 as there isn't one (Although it's probably similar to the R33 install), not sure if I will though, as it's my first time and it's gonna take me long enough as it is. :rofl2:
haha awesome. Which wheels did you go with in the end? And i'm guessing you found out which type of coilovers you need? Looking forward to seeing the end result. Oh and i'm also demanding before and after pics for wheels and coilovers. Cheers
Ended up with Silver Koya Drift Teks with some Nitto NT05 rubbers on them, not sure what I think of them yet, maybe because the car is too high atm, will have to wait on the coilovers. :D
I'll be sure to get some pics when it's all done. :thumbsup:
hi here is my car with its new project d wheels they look cool but i think the ride still sits to high IMO.
i already have to get the front guards rolled tomorrow due to them scraping when i hit slight bumps.
what are your guys oppinions looks low enough or lower (back looks really high)?
cheers.
looks really high in this pic.
There's something that just doesn't look right, I get the same feeling with mine.
Seems like it's too high or the wheels are too big, something just looks odd.
Can't quite put my finger on it....
EDIT: Maybe try more low?
Edited by Converge
    • I've sent JaseR33 a private message in the hope he gets an email and contacts you
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
