hi guys. i have a wolf3d v4 plugin on my rb25-30 setup. the tuner guy say it is getting no crank signal. is there something in the settings to setup to make it work? he says he thinks there should be something in the setup bit of it but cant find it yet. if you could help it would be great. thanks guys
https://www.sau.com.au/forums/topic/364017-wolf3d-v4-rb25det-plugin-setup/
Does it still require a wolf disc in the CAS?
Check there is power going into the CAS. Maybe one power out is not working. If the CAS doesnt have power. Try powering it up with a wire direct from the battery or similar. Then see if the signal is working inside the ecu
