This will probably be shot down pretty quick, but if its a new product it might be a new option.
I've been speaking to an Adelaide tuner about doing something for the M35. Initially I was asking about Emanage, but he was reluctant as apparently they use an addition/subtraction table instead of dictating their own. His suggestion was a Haltech standalone, however when I pointed out all the difficulties, he went back to the drawing board, however did speak to Haltech.
Haltech's response:
"The Platinum Sprint 500 now supports the 350Z VQ35 trigger system. I am assuming the VQ25 engine uses the same trigger system (A scope trace to verify this would be perfect).
In the case of the trigger system being the same you could use the platinum Sprint for fuel, ignition and boost control on the engine in piggy back format. This is not an interceptor style ECU."
I wouldn't think the VQ25 would be the same as the VQ35, since nothing seems the same engine/ECU wide, but I figured it might be worth asking the question about the trigger system.
If they do share a trigger system, we would be able to run the Platinum Sprint, which is under $1k, almost as a stand alone, with the standard ECU controlling the auto.
Under this setup, the Platinum Sprint 500 controls spark and fuel directly, so no addition/subtraction tables, and apparently 'even if the main ECU tries to introduce a speed cut it has no effect.'
Haltech web site: http://www.haltech.com.au/index.php/product/platinum-sprint-series/platinum-sprint-500
I spoke to Craig about his previous experience with the Haltech, and it sounds like if you get the right product it might work. He did get it working, but he was using a Platinum Interceptor and it wasn't working properly with the AFM signal.
The only thing I'm not sure about with this is the throttle. Would this be an issue?
Anyone interested in this or know anything about it?
https://www.sau.com.au/forums/topic/364025-haltech-platinum-sprint-500/
The Motec M800 can control the throttle but its expensive. By the looks of it you could run this unit, but I would need to see the input/output capabilities. If it has a few spare PWM outputs you could drive the cams at least.
Yes, they share the same crank trigger as my Emanage uses the VQ35 trigger setup. (theres no VQ25det engine data)
Swapping to a cable throttle is the least of your problems. This will be a long process to get right and you will be paying for all the development time like I have with the Emanage. Is it better? I doubt you will notice the difference if the tuner is good enough.
Well that's part of what I'm following up with him, I doubt for me its worth doing all the development even if it will be better, but for someone like you it might be useful. Depends on the development costs I guess, its not much dearer than an Emanage to buy the unit.
Have a look at the Platinum Sprint 500 Spec Sheet, has some promising stuff on it. It has two generic programmable inputs, and looking in the manual it mentions "Digital Pulsed Inputs". Been a while since I did electrical engineering, not sure if you can get the same thing out of it!
    • Ah yes but were you responsible? In the time I've had it (just before Christmas) I spun off the track twice and drove into things twice, so four separate incidents.. in two outings. Luckily I have a full OEM GTR front end to put on which is hopefully not a precursor for further, future, more expensive mistakes to come. It is some consolation that anyone who would want to buy my Altia bar would have to paint it anyway, the guards, too. (if they can get over the asymmetry). Hopefully over the weekend I will disassemble and see how badly things are bent. From what it looks like, the headlight has actually just been pushed back and bent the headlight support (which .. somehow... crushed the guard in). I guess the headlight plastic is strong stuff.
    • These things happen And I believe "we, the people, who modify stuff, and actually use it, cannot have nice things" It's just a shame that it happened so soon after paint  I still win the award for quickly destroying newly painted panels I think, as my car came back from the paint shop all nice and shiny, until about 4 hours later when the boot was destroyed by a wayward locker that was blown around by the wind.... What doesn't kill you makes you stronger, and poorer.....dooh
    • This. And also, the rotor thickness is constrained by the calipers. Cannot be much thicker, if at all. Cannot be much thinner, if at all. New rotors are....fairly cheap. Turbo calipers can still be picked up for sensible money. Arguably, the best thing is to get R32 calipers and put them on mount spacers on 324mm discs. That's about the cheapest and easiest way to get quite large brakes that are essentially bolt on. And that's despite maintaining for years that the R32 calipers are not the best choice because they seem to be more flexy and creaky than the others. If you were prepared to put up with nasty little NA sliding calipers, these will still seem like Brembos by comparison.
    • A quick Google said 297mm..
    • Why would you not fit the biggest possible brakes?
