hi have a 33 ive had for awhile
things have changed so need to get rid of it
all interior parts
front seats - $150
rear seats - $100
seat belts - $50 each
rear shelf - $30
carpet - $100
dash facia - $40
glove box - $30
centre console - $50
door cards - $40 each
rear plastics - $20 each
a / b / c pillar plastics - $10 each
hood lining - $80
exterior parts
boot - $100
series 1 wing - $50
series 2 wing - $50
m spec side skirts - $100
400r rear pods - $100
tail lights - $50 each
passenger side door
all glass
drivers side gaurd - $100
dash loom - $100
r33 front strut brace - $100
front brakes - $300 with rotors
rear brakes - $200
wipers
fuel tank - $100
brake lines
fuel lines etc etc
engine bay items
rb25det injectors - $80 or $100 on rail
rb25det CAS - $70
rb25 starter - $60
rb25 alternator - $60
rb25 inlet plenum - $100
rb25 turbo manifold - $50
rb25 series 2 engine loom - $150
rb25det 5 speed ecu - $100
rb25 engine cross member - $100
r33 power steering resevior - $40
r33 steering rack - $100
r33 engine fuse box - $40
rb25det series 1 coil packs - $80
rb25det series 2 coil packs - $100
rb25det series 1 coil pack loom no broken clips :) and ignighter - $60
rb25det series 2 coil pack loom no broken clips - $30
rb25det stock cams - $50
WILL ALSO DO THE SHELL AS FRONT OR REAR OR PANEL CUTS ETC ETC
PROBLY OTHER THINGS IVE FORGOTTEN
HIT ME UP FOR ANYTHING UR LOOKING FOR
CAN ALSO TEXT ME ON 0435494669
HAPPY TO MAIL SMALLER ITEMS
IM LOCATED NORTHERN NSW NEAR BYRON BAY
CAN DELIVER ITEMS AS FAR UP AS BRISSY IF WANTED
THANKS
Edited by team carefactor
https://www.sau.com.au/forums/topic/364032-wrecking-r33/
  • Replies 69
hi everyone
yeah i do have series 1 inner gaurds
no drivers side window switch
no manual gear surround
yes i do have AFM
and yes do have both washer bottle motors
thanks
https://www.sau.com.au/forums/topic/364032-wrecking-r33/#findComment-5813468
hi everyone
yes i do have AFM
thanks
Price?
https://www.sau.com.au/forums/topic/364032-wrecking-r33/#findComment-5813536
    • He made that comment in my thread - In my case the vents ARE to lower engine heat, when the car is not moving, which is the only scenario I have heat problems with the aircon on, sitting in traffic, on 40C+ days. I can't imagine a scenario that this NC needs any at this point in time. I do not know if it will actually make my cooling when the car is MOVING worse, and I sincerely hope that won't be the case. If it does, well, um, f**k.
    • Nice, thanks. Thats why I was asking, there'd been a fair bit of discussion in the E90 world about vents and where it makes sense to put one (ie, over the filters is not great as that is inline or slightly behind the struts and in higher pressure area). I struggle with air flow and pressures. It sill weirds me out that a radiator in the boot can work.
    • Neither really Vents, when located in the right place, will lower the engine bay "pressure", as air has a path to escape, thus lowering the engine bay pressure, thus.....improving the efficiency on the coolant stack (read: IC, condenser, radiator) This is why the Blits vented bonnet on my 33 worked so well, the vent was in the front 1/3 of the bonnet, which put it right after the radiator  If the vents are to far back toward the windscreen, which is a high pressure zone, it can actually force air into the engine bay, causing higher pressure and effectively loosing efficiency on the cooling stack, like the fab of raising the rear of the bonnet, which does allow heat to escape, but only when the car isn't moving  There's heaps of cool "fluid dynamics" info out there, but, I'll attach a video of a 'Merican joint that focuses on "Miatas" as I found it when looking into vents for mine, they explain it way better than me
    • Poor bleeding. That stupid damping loop in the plumbing that should be completely replaced with a braided hose. Just the first 2 that come to mind.
    • Forgive the potentially silly question but are the vents for bay temps? I've been toying with how to reduce my bay temps because man, it gets HOT in there and a small subtle vent somewhere I think might help. Or, maybe they're to assist with just the intake temps?
