hi have a 33 ive had for awhile
things have changed so need to get rid of it
all interior parts
front seats - $150
rear seats - $100
seat belts - $50 each
rear shelf - $30
carpet - $100
dash facia - $40
glove box - $30
centre console - $50
door cards - $40 each
rear plastics - $20 each
a / b / c pillar plastics - $10 each
hood lining - $80
exterior parts
boot - $100
series 1 wing - $50
series 2 wing - $50
m spec side skirts - $100
400r rear pods - $100
tail lights - $50 each
passenger side door
all glass
drivers side gaurd - $100
dash loom - $100
r33 front strut brace - $100
front brakes - $300 with rotors
rear brakes - $200
wipers
fuel tank - $100
brake lines
fuel lines etc etc
engine bay items
rb25det injectors - $80 or $100 on rail
rb25det CAS - $70
rb25 starter - $60
rb25 alternator - $60
rb25 inlet plenum - $100
rb25 turbo manifold - $50
rb25 series 2 engine loom - $150
rb25det 5 speed ecu - $100
rb25 engine cross member - $100
r33 power steering resevior - $40
r33 steering rack - $100
r33 engine fuse box - $40
rb25det series 1 coil packs - $80
rb25det series 2 coil packs - $100
rb25det series 1 coil pack loom no broken clips :) and ignighter - $60
rb25det series 2 coil pack loom no broken clips - $30
rb25det stock cams - $50
WILL ALSO DO THE SHELL AS FRONT OR REAR OR PANEL CUTS ETC ETC
PROBLY OTHER THINGS IVE FORGOTTEN
HIT ME UP FOR ANYTHING UR LOOKING FOR
CAN ALSO TEXT ME ON 0435494669
HAPPY TO MAIL SMALLER ITEMS
IM LOCATED NORTHERN NSW NEAR BYRON BAY
CAN DELIVER ITEMS AS FAR UP AS BRISSY IF WANTED
THANKS
Edited by team carefactor
https://www.sau.com.au/forums/topic/364032-wrecking-r33/
  • Replies 69
hi everyone
yeah i do have series 1 inner gaurds
no drivers side window switch
no manual gear surround
yes i do have AFM
and yes do have both washer bottle motors
thanks
https://www.sau.com.au/forums/topic/364032-wrecking-r33/#findComment-5813468
hi everyone
yes i do have AFM
thanks
Price?
https://www.sau.com.au/forums/topic/364032-wrecking-r33/#findComment-5813536
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
