hi have a 33 ive had for awhile
things have changed so need to get rid of it
all interior parts
front seats - $150
rear seats - $100
seat belts - $50 each
rear shelf - $30
carpet - $100
dash facia - $40
glove box - $30
centre console - $50
door cards - $40 each
rear plastics - $20 each
a / b / c pillar plastics - $10 each
hood lining - $80
exterior parts
boot - $100
series 1 wing - $50
series 2 wing - $50
m spec side skirts - $100
400r rear pods - $100
tail lights - $50 each
passenger side door
all glass
drivers side gaurd - $100
dash loom - $100
r33 front strut brace - $100
front brakes - $300 with rotors
rear brakes - $200
wipers
fuel tank - $100
brake lines
fuel lines etc etc
engine bay items
rb25det injectors - $80 or $100 on rail
rb25det CAS - $70
rb25 starter - $60
rb25 alternator - $60
rb25 inlet plenum - $100
rb25 turbo manifold - $50
rb25 series 2 engine loom - $150
rb25det 5 speed ecu - $100
rb25 engine cross member - $100
r33 power steering resevior - $40
r33 steering rack - $100
r33 engine fuse box - $40
rb25det series 1 coil packs - $80
rb25det series 2 coil packs - $100
rb25det series 1 coil pack loom no broken clips :) and ignighter - $60
rb25det series 2 coil pack loom no broken clips - $30
rb25det stock cams - $50
WILL ALSO DO THE SHELL AS FRONT OR REAR OR PANEL CUTS ETC ETC
PROBLY OTHER THINGS IVE FORGOTTEN
HIT ME UP FOR ANYTHING UR LOOKING FOR
CAN ALSO TEXT ME ON 0435494669
HAPPY TO MAIL SMALLER ITEMS
IM LOCATED NORTHERN NSW NEAR BYRON BAY
CAN DELIVER ITEMS AS FAR UP AS BRISSY IF WANTED
THANKS
Edited by team carefactor
https://www.sau.com.au/forums/topic/364032-wrecking-r33/
  • Replies 69
hi everyone
yeah i do have series 1 inner gaurds
no drivers side window switch
no manual gear surround
yes i do have AFM
and yes do have both washer bottle motors
thanks
https://www.sau.com.au/forums/topic/364032-wrecking-r33/#findComment-5813468
hi everyone
yes i do have AFM
thanks
Price?
https://www.sau.com.au/forums/topic/364032-wrecking-r33/#findComment-5813536
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
