Hi all. I have a 1999 Black Stagea rs four s series 2 manual with the NEO 6 engine. Has been great for the last 5 years. I have just started having a problem with the engine check light coming on.
I had it checked out and the O2 sensor was replaced. Now the light only comes on just after the auto chock cuts off. If I stop and restart the engine the light does not come back on. Has anyone had
similar problems and if so what was the fix ?
https://www.sau.com.au/forums/topic/364038-info-required/
I have a 2000 RS4 Tiptronic that recently had a similar fault at idle and sometimes whilst driving, the engine would noticeably miss and at the same time the engine check light would come on; this progressed over a two week period and eventually it would do it around the same period of time as you describe. I had two different mechanics run their scanner on the diagnostic port and they both came up with the same fault which from memory was "Primary ignition circuit" in other words the coil packs were breaking down. This may or may not be related to your problem but it seemed to be heat related as when the "choke" cut off i.e. the engine had warmed up, the coil packs played up.I replaced the coil packs with Splitfires from JustJap and the spark plugs while I was in there and haven't had a problem since. The coil packs are a known problem with these engines. good luck, keep us posted.
Regards Craig
https://www.sau.com.au/forums/topic/364038-info-required/#findComment-5809114
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
    • Being a manual, we very quickly ordered new R34 gearbox (From Nissan) and remaining parts from Kudos motorsports. Would highly recommend the team there. Ultra helpful and quick to share advice and upgrades. We are in the middle of taking the Auto out (Genuine 94,000/kms) and putting the Manual in this weekend. Part 2 of the build will include likely a Plazaman Intercooler and Plenium, Hks Exhaust with Tomei Dump (ordered).
