R33 gts-t rb25det Genuine manual radiator in good working condition $50
Sniper carbon door scuffs both sides to suit a nissan 2door r33 skyline(never used) $90
gtr drag intercooler core size 600mm x 290mm x 120mm, inlet & outlet 80mm, overall length 1070mm(was used on my r33 with around 204kw and hade no probs. only 300km of use. $250 ono
R33 gtst overflow and washer bottle $25 for both
R31 cluster reads 313967 from a 89 oz spec(been sitting in my shed for 3yrs was working before i took it out)$30
R33 Air Conditioning Condenser gtst 1994 $50
pm me
Dave
R33 gtst sr1 tailshaft $100
will have more r33 gtst parts for sale as soon as i finsh sorting out my shed, gtr spoiler,carbon bonnet and many more parts.
https://www.sau.com.au/forums/topic/364044-shed-clean-out/
  • Replies 116
R33 gtst sr1 front wiper motor $30
R33 gtst sr1 rear wiper motor $50
R33 gtst sr1 brake booster and master cylinder $100
Rb25det sr1 sump $50
R33 gtst sr1 climate control $50
R33 gtst fuse box and cover $30
R33 gtst sr clutch master cylider $50
R33 gtst sr1 bonnet hinge set $20
R33 gtst sr1 tail shaft $100
https://www.sau.com.au/forums/topic/364044-shed-clean-out/#findComment-5812478
Sniper carbon door scuffs both sides to suit a nissan 2door r33 skyline(never used) $80
gtr drag intercooler core size 600mm x 290mm x 120mm, inlet & outlet 80mm, overall length 1070mm(was used on my r33 with around 204kw and hade no probs. only 300km of use. $230
R31 cluster reads 313967 from a 89 oz spec(been sitting in my shed for 3yrs was working before i took it out)$25
R33 Air Conditioning Condenser gtst 1994 $40
pm me
Dave
Price drop
https://www.sau.com.au/forums/topic/364044-shed-clean-out/#findComment-5815557
il take a pic of carbon bonnet and gtr spoiler this sat
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $100
R33 gtst battery tray need painting $20
R33 clutch master cylinder $30
R33 manual gear shift boot/plate $20
https://www.sau.com.au/forums/topic/364044-shed-clean-out/#findComment-5819208
r33 gtst sr1 carbon bonnet bought from autobarn paid $1300 a few years back only used on my car for a few months just been sitting in my shed. has a few light scratches $500 ono
R33 gtr spoiler needs a rub back and paint no end caps $250
R33 4door front lights $250
https://www.sau.com.au/forums/topic/364044-shed-clean-out/#findComment-5825685
pm me
Dave
R33 gtst sr1 manual tailshaft $80
RB25 Alternator $55
RB25 Starter Motor $50
R33 gtst sr1 brake booster and master cylinder $80
https://www.sau.com.au/forums/topic/364044-shed-clean-out/#findComment-5835142
where are you located?
  • Gender:Male
  • Interests:Imports
  • Car(s):R33 gts-t R31det & 240k
  • Real Name:Dave
Hope that helps? :thumbsup:
https://www.sau.com.au/forums/topic/364044-shed-clean-out/#findComment-5842488
R33 gtst sr1 rear wiper motor $40
R33 gtst sr1 brake booster and master cylinder $70
Rb25det sr1 sump $40
R33 gtst sr1 climate control $40
R33 gtst fuse box and cover $20
R33 gtst sr clutch master cylider $30
R33 gtst sr1 tail shaft $80
PRICE DROP
https://www.sau.com.au/forums/topic/364044-shed-clean-out/#findComment-5852224
RB25 Alternator $55 SOLD
RB25 Starter Motor $50 SOLD
R33 gtst sr1 radiator fan and hub SOLD
PRICE DROP ON MOST ITEMS
RB25det sump $40
R33 sr2 wing needs paint $40
GTR wing no end caps needs painting $200
R33 gtst sr1 rear wiper motor $35
R33 gtst sr1 brake booster and master cylinder $65
R33 gtst sr1 bonnet hinge set $15
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $70
R33 gtst battery tray need painting $15
R33 gts-t rb25det Genuine manual radiator in good working condition $45
RB25 R33 GTST SR1 CAS CAM ANGLE SENSOR AND BRACKET $55
R33 RB25 skyline power steering reservoir with lines $20
pm me or 0435888239
Will post at buyers expense
https://www.sau.com.au/forums/topic/364044-shed-clean-out/#findComment-5871936
rb25det tailshaft SOLD
sniper scuffs SOLD
RB25det sump $40
RB25det fuel rail $20
RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $25
R33 Air Conditioner Compressor with lines as seen in pic $65
r33 gtst front door speaker pods $10
RB25det sr1 aac valve $50
pm me or 0435888239
https://www.sau.com.au/forums/topic/364044-shed-clean-out/#findComment-5872934
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
