  • Replies 116
RB25 clear timming belt cover SOLD
RB25det fuel rail SOLD
RB25det sump $30
R33 sr2 wing needs paint $30
GTR wing no end caps needs painting $150
R33 Air Conditioning Condenser gtst 1994 $35
R33 gtst sr1 front wiper motor $30
R33 gtst sr1 rear wiper motor $35
R33 gtst sr1 climate control $35
R33 gtst fuse box and cover $20
R33 gtst sr1 bonnet hinge set $15
R33 gtst overflow and washer bottle $25 for both
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $50
R33 gtst battery tray need painting $10
RB25 R33 GTST SR1 CAS CAM ANGLE SENSOR AND BRACKET $45
R33 clutch master cylinder $30
R33 RB25 skyline power steering reservoir with lines $20
RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20
R33 Air Conditioner Compressor with lines as seen in pic $55
RB25det sr1 aac valve $40
r33 gtst sr1 carbon bonnet $400
fiberglass vent (uncut vent) $50
rb25 turbo 45v2 has a blown seal $50
R33 gtst sr1 abs unit and bracket $60
Rb25det sr1 flywheel $40
R33 gtst coupe sr1 door handle's $30
R31 sr3 grill $10
R31 sr3 bits lot $15
R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25
R33 gtst light garnish $30
R33 centre interior light plus other? $25
R33 turbo oil drain pipe $10
rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $80
r33 horns $10
r33 sr1 bonnet in primer has a few scratches and a small dint from sitting in the shed $120
catco high flow cat 2.5inch 325mm long $50
apex rb25 front pipe 2.5inch has a few dings $70
Nismo muffler 2.75mm inlet with 4.5inch tip $130 plus rear section that suits r33 free with muffler
RB hard oil turbo line $25 (not sure if its rb20 or rb25)
RB hard water turbo line 1 $25 rb20 rb25?
RB turbo hard water line 2 $25 rb20 rb25?
R33 gtst window wiper set $ 15
R33 gtst sr1 electric driver side window switch and loom $50
R33 gtst sr1 passenger side electric window switch and loom $45
R33 gtst sr1 2door seat belts(not sure if its complete) $50
R33 gtst sr1 air con units that sit behind the dash $100
pm me or 0435888239
Will post at buyers expense
Dave
R33 clutch master cylinder SOLD PENDING PAYMENT
R33 gtst battery tray need painting SOLD PENDING PAYMENT
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
rb25 custom coil pack cover never used(nismo)$80
RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $25
pm me or 0435888239
Dave
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler
rb25 custom coil pack cover never used(nismo)$70
RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20
pioneer reverse camera bought it 2 years ago for $100 from jb hifi but never used it. $25
vr v6 commodore sedan fuel sender and pump(pulled from running car but hade different plugs to myn) $40
pm me or 0435888239
Dave
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
rb25det sr1 head in good condition pulled from running engine 80k and only 10psi stock turbo $120
pm me or 0435888239
Dave
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rb25det charcol canister $20
r33 boot latch with plug $20
R33 boot and fuel lever $15
R31 1989 oz spec bonnet latch and lever $15
R33 a/c receiver,drier sensor $30
rb25det fuel modulator with bracket$25
pm me or 0435888239
Dave
r33 gtst sr1 carbon bonnet SOLD PENDING PAYMENT
rb25det sr1 head in good condition SOLD PENDING PAYMENT
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
pm me or 0435888239
Dave
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
will have pic soon
R33 gtst R/H drivers door glass $40
R33 gtst L/H drivers door glass $40
R33 front window $80
R33 rear window $100
R33 gtst front fenders rolled and liped $200 for both
pm me or 0435888239
Dave
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
will have pic soon
relist due to time waster
R33 sr1 eyelids(they need prep work before paint)$15
pm me or 0435888239
Dave
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 stereo brackets $20
R33 sr1 dash trim(needs a clean and paint) $50 sorry about ph pics
pm me or 0435888239
Dave
PRICE DROP ON A FEW ITEMS
RB25det sump $30
R33 Air Conditioner Compressor with lines as seen in pic $50
R31 sr3 grill $10
rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70
r33 horns $10
r33 sr1 bonnet in primer has a few scratches and a small dint from sitting in the shed $110
apex rb25 front pipe 2.5inch has a few dings $60
R33 gtst sr1 air con units that sit behind the dash $90
rb25 custom coil pack cover never used(nismo)$60
R33 rear window $80
R33 gtst front fenders rolled and liped $180 for both
pm me or 0435888239
Dave
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $80
pm me or 0435888239
Dave
rb25 custom coil pack cover never used(nismo)SOLD PENDING PAYMENT
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $80
pm me or 0435888239
Dave
R33 sr1 eyelids SOLD
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $80
pm me or 0435888239
Dave
R33 gtst sr1 electric driver side window switch and loom SOLD PENDING PAYMENT
RB25det sump $30
GTR wing no end caps needs painting(plastic) $150
R31 sr3 grill $10
r33 horns $10
R33 rear window $80
pm me or 0435888239
Dave
r33 sr1 bonnet in primer SOLD PENDING PAYMENT
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $80
pm me or 0435888239
Dave
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $80
pm me or sms 0435 888 239
Dave
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
