R33 Air Conditioning Condenser SOLD PENDING PAYMENT
R33 rb25det charcol canister SOLD PENDING PAYMENT
RB25det sump $30
R33 sr2 wing needs paint $30
R33 gtst sr1 front wiper motor $30
R33 gtst sr1 rear wiper motor $35
R33 gtst sr1 climate control $35
R33 gtst sr1 bonnet hinge set $15
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $50
R33 RB25 skyline power steering reservoir with lines $20
RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20
R33 Air Conditioner Compressor with lines as seen in pic $50
RB25det sr1 aac valve $40
fiberglass vent (uncut vent) $50
R33 gtst sr1 abs unit and bracket $60
Rb25det sr1 flywheel $40
R33 gtst coupe sr1 door handle's $30
R31 sr3 grill $10
R31 sr3 bits lot $15
R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25
R33 gtst light garnish $30
R33 centre interior light plus other? $25
R33 turbo oil drain pipe $10
rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70
r33 horns $10
Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler
RB hard oil turbo line $25 (not sure if its rb20 or rb25)
RB hard water turbo line 1 $25 rb20 rb25?
RB turbo hard water line 2 $25 rb20 rb25?
R33 gtst window wiper set $ 15
R33 gtst sr1 passenger side electric window switch and loom $45
R33 gtst sr1 2door seat belts(not sure if its complete) $50
R33 gtst sr1 air con units that sit behind the dash $90
RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20
pioneer reverse camera bought it 2 years ago for $100 from jb hifi but never used it. $25
vr v6 commodore sedan fuel sender and pump(pulled from running car but hade different plugs to myn) $40
r33 boot latch with plug $20
R33 boot and fuel lever $15
R31 1989 oz spec bonnet latch and lever $15
R33 a/c receiver,drier sensor $30
rb25det fuel modulator with bracket$25
R33 gtst R/H drivers door glass $40
R33 gtst L/H drivers door glass $40
R33 rear window $70
R33 gtst front fenders rolled and liped $170 for both
R33 stereo brackets $20
R33 sr1 dash trim(needs a clean and paint) $40
R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25
r33 sr1 bonnet in primer$100 has a small dent(can send pics)
R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $50
R33 gtst false rear wall $20
R33 gtst sr1 coupe rear quarter trims LEFT & RIGHT they just need a clean but in good con $50
RB25det stock dump on black vht $20
R33 gtst rear bar with gtr pods both will need repair $50
r33 gtst sr1 power window motor regulator LHS $80
r33 gtst sr1 power window motor regulator RHS $80
I have r33 interiour parts, pm for what you after
pm me or sms 0435 888 239
Will post at buyers expense
  • Replies 116
R33 gtst sr1 climate control SOLD PENDING PAYMENT
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
RB25det sump $30
R33 Air Conditioner Compressor $40
R31 sr3 grill $10
r33 horns $10
vr v6 commodore sedan fuel sender and pump(pulled from running) $40
R33 rear window $70
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
R33 gtst rb25det hicas computer $60
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
ARP RB20 RB25 HEAD STUDS BOLTS KIT NEW NEVER USED $170(was going to build a forged rb25 for my 31 but now need money for another project)
ARP rb25 Exhaust Manifold Kit new never used $100
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
ARP RB20 RB25 HEAD STUDS BOLTS KIT NEW NEVER USED $150(was going to build a forged rb25 for my 31 but now need money for another project)
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET SOLD PENDING PAYMENT
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
R33 bonnet in black primer has a small bend in lip $50( can get pic)
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
R31 1989 sr3 front calipers( pulled from running car but have been sitting for 3 years) $30
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 gtst sr1 air con units that sit behind the dash, heater cores $90
R33 rear window $70
R33 gtst rear bar, will need repair $25
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
r33 gtst sr1 power window motor regulator d/s $80 SOLD PENDING PAYMENT
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 gtst sr1 2door seat belts complete $50
R31 1989 oz spec bonnet latch and lever $10
R33 rear window $70
R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $40
R33 gtst rear bar, will need small repair $25
r33 gtst sr1 power window motor regulator passenger side $80
R33 gtst rb25det hicas computer $50
R31 1989 sr3 front calipers( pulled from running car but have been sitting for 3 years) $20
Dave
ARP RB20 RB25 HEAD STUDS BOLTS KIT SOLD PENDING PAYMENT
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
Rb25det sr1 cas with bracket $50
Dave
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
Dave
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
r33 gtst sr1 power window motor regulator passenger side $70
Dave
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
Dave
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 rear window $70
Dave
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
