For sale
Nissan Skyline GTR R32 ,1993.
Unfortunately, due to financial reasons alone, the GTR has to be sold. It's in excellent condition, with no rust at all. When I was looking for GTRs, I found alot of them had rust all through the rear arches especially. If they didn't, you could put your hand up under the lip and feel all the weld and bog where it'd been repaired. This car has untouched arches, they are perfect.
Car shows 78,600kms on the clock. Now, as we all know, Japanese cars are reknowned for having the odometers wound back, however this car has a sticker on it from the MTA stating the kms are original. Sticker was there when I bought it from the importer. I'm not saying that what this sticker reads is rock solid information, the only thing I will add to that is; how the car drives and the condition is consistent with the mileage. I will leave it up to the individual to make up their own mind, because the bottom line is that it's be very hard to prove either way.
I bought it with 73,500km on the clock in Oct '09.
Engine
Nice and tight, no rattles, leaks or smoke, and runs very smooth. Nitto s/s inlet manifold gaskets, cat back exhaust, standard airbox with K&N filter (can supply pods if required, but in my opinion they are for hand racing only. Seems to make the same or even more power with the airbox)
It has a Nistune and 550cc injectors. (standard tune, bar the setting required for injectors). I fitted these in preparation for doing turbos and all that, but my direction in life is changing somewhat and that has never happened. So turbos are standard (as far as I know), never been boosted or fiddled with in my ownership. It runs approx 9psi boost. On a dyno day it made 206kw at the tyres.
However it does have the standard GTR high idle.
Driveline
All good. No problems. Has Tein coilovers.
Interior
In good condition. Seats have no rips. Has a Sard Attack meter, a turbo timer, and a new stereo with iPod cable and remote control. It also has a Nardi steering wheel.
Exterior
As mentioned, it's straight with no rust. Paint is good with a few tiny marks.
Overall it's a good car. It's lived in the garage the whole time I've had it. It has a few little issues like the ABS light coming on intermittently, but that's the sensor on the front wheel. I'll have that sorted before sale.
I've also kept a thorough maintenance record, with everything I've done to it, kms, date etc.
It has 10 months NSW rego. Car located in Sydney.
Price: $23,500 ono
If you're interested give me a call. You can email, pm or text, but in the past I've found people who do that are generally time wasters. Keen buyers call.
Cheers,
Dan
0406 441 672
https://www.sau.com.au/forums/topic/364081-skyline-r32-gtr-for-sale/
  • 1 month later...
very nice car man, but you are asking for alot , therefore u might wait a while for a sale or might never even sell it.. i just bought my 1994 R32 GTR in silver for 16.3k with 68000 kz , i had MTA inspect it like u did. came out perfect !
Edited by sultanaz
Stick to your price Dan , theres to many jerk off lowballers around ,
Your car looks in perfect condition i paid 25k for an R32 not that long ago !!!!! Good Luck
try carsales.com.au as you pay once to run the ad until sold. worth it imo
advertised my old GTT on here & at a lower price than what I advertised on carsales & still got lowballers :rolleyes:
good luck with your sale
  • 1 month later...
Been perving on this car on carsales for a while now :P
Even though it's an amazing example of a 32 gtr, People seem to not be buying at the moment, So i'd say somewhere between 18-20k unless you want to hold onto it for a while.
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
