post-80841-0-82125200-1305247492_thumb.jpg Hi Guys. Got a few parts for sale.
ATR43G3 Turbo
Km: 3000km Or less (Basically new)
Technical: ATR43G3 Turbo .82 internally gated.
Condition: No shaft play (When bought was taken to Yavuz at UniGroup And he said the turbo felt great).
INCLUDING: stock exhaust mani AND a Stainless Steel Dump pipe.
Due to some personal issues i have been unable to install the turbo. I bought it off ( MBS206 ), Who is a NSW Executive. So if you have questions about the turbo's past just send him a PM hell vouche for the turbo :). As i said i havent even used it since getting it. The turbo itself is running a hypergear High pressure actuator rated at 14PSI. This type of turbo has been seen making 300RWKW+ if on E85 you could be looking at more.
PRICE: $850 ONO (NO LOW BLOWS)
TIEN SUSPENSION NR Suit R33 GTST series 1 or 2.
Ok guys Ive got these laying around i don't need them. There selling DIRT cheap because the rear passenger side has a minor leak easily fixed but i need them gone
PRICE: $250 FIRM
ALSO.
TRUST REAR BAR
Will Suit R33 GTST all Models. NEVER used got it with the car when bought as an extra. Still in original Gel.
PRICE: $200 FIRM
Pictures are below. All located in Sydney will post at buyers expense.
Contact: 0401200176 (msg me cause i work and ill call you back.) No clowns please,
Regards
Sid
are you goin to post the items ive texted but no reply can u send me the dump pipe asap then ill take the rest after that cheers
You haven't sent me any address details buddy. I cant send them via The post if you dont give me the address, Plus theres other people interested. If someone local grabs it before i can send it via post then great.. Im sorry mate but i work 8 30 to 5... And my boss wont let me have time off this week to just drop into the post office to send it. So if i was to send it i can only make it by saturday, so ive been flat out busy thats why you havent recieved a replay yesterday and today.
Sid
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
