hey sid
can i inspect the bar this saturday arvo? im in sydney as well. let me know.
Jim
Hey buddy :). Sure you can my number is 0401200176, send me a message and ill let you know the address.
Cheers
Sid
Turbo still not sold... Had major drama's happen been uncontactly for the past week or so.. Please continue inqueries coming. If possible keep it sydney only please, i will contact interstate buyers who are still awaiting a replay.
Thank you
Sid
I was going to buy the turbo. I rang and arranged it and you still hadn't posted it 5 days later. Mate if you want to sell it then you gotta post it. :down:
Ya look. Like i said ive had quiet a few issues atm here at home... Look if none local comes this weekend ill have it done and posted this Monday.
Sid
Sid
Mate, I told you I'd buy this turbo 3 weeks ago & as far as I knew you were sending it that weekend!! Then I hear nothing & get no response to my enquiry's??
I was willing to front the money on the spot.
How many turbo's are you selling?......
? only one mate... Like i said having to send it via post, has turned into a huge fiasco at the wrong time. Not your fault i never said that it is my fault ive had things coming up... i'll message you tomorrow if i can get it boxed in a proper box that wont break under the weight... thats if you still want it.
sid
But this is confusing.. Ive had 2 interstate buyers that were serious.. 1 of you backed out because i wouldnt lower the price to what you wanted even though we'd agreed on the price. It was "DALE" that i never sent the package to and like i said im sorry, theres been personal drama's and i apologize for not messaging dale.
Sid
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
