1989 R32 Gts-t Type M.
ENGINE: rb20det rebuilt ( recipts ) front mount resprayed non gloss black with hard pipe kit, turbosmart bov, 3" exhaust hi flow 3" cat, microtech lt-12s comes with hand controller, direct earth wiring kit, R34 series one turbo, boxed pod, also have highmount manifold, 38mm tial gate, 3" dump to suit high mount.
DRIVELINE: brass button clutch, 4.3 diff locked, short shifter,
SUSPENSION : nismo adjustable shocks, unknown springs ( red ), kkr adjustable castor rods, new tie rod ends.
BRAKES: factory type m brakes with new pads and been painted vht blue.
EXTERIOR: resprayed unknown blue inside & out except engine bay, gtr front bar with lower n1 lip, factory type m side skirts, type m rear pods, stock type m wing or n1 boot lip, Work VS - Edition 17x8 +30, 17x9 +35 comes with all centre caps, tinted windows,
INTERIOR: all factory Gts-t, besides autotechnica wheel, drift shift knob, greedy ext temp guage, drift boost guage ( not installed ) monsta tacho with oil temp oil pres, shift light, no head unit or speakers,
Odds & ends:
Spare 16x7+30 hinodex wheels good tyres.
Spare Rb20det head.
Spare R32 gtst taillights.
Alloy catch can.
R32 gtr front bar n1 lip genuine, R32 gtr fiberglass copy.
N1 boot lip.
Stock rb20 turbo.
Stock intercooler.
High mount manifold.
Tial 38mm gate.
New drift boost guage, and cup
New drift gear knob.
H.I.D. kit like new.
Short shifter.
Other shit like r33 lcas.
Probaly more.
The bad:
Running rough been told it could be because of the 34 turbo recently fitted needs some nipple welded into intake or something because of different wastegate setup.
Car has dent in drivers door and sill from previous owner have spare door and the side skirt covers sill damage :P also from previous owner rear pillar has been hammered
No rego.
Can come with blue slip!
Has custom plates EVL.32R
Dash says 97,000 k's but import papers say 127,000 k's so obviously been changed.
Car is located in singleton nsw locked away in a shipping container. Havent even driven it just bought it and stored it away.
Im intersted in swaps for a regoed import, or xr6 ute, 4x4 etc
$6500 ono with blue slip!
0432163488 jahn
Will have pics up as soon as i have acess to a computer for now msg my fone and ill send some thru cheers!
https://www.sau.com.au/forums/topic/364089-r32-gts-t-type-m/
OK UPDATE! The 32 is running fine the solution you ask? I had the microtech lt-12s pluged in and it wasnt tuned for the internal wastegated low mount setup. Plugged the stock ecu in and she runs like a pearler!
So all she needs is rego and your on ya horse!
Also have a vp commodore 5 speed wagon in immaculate condition all standerd besides tinted windows and sports ryder rear swaybar. And a ford laser tx3 1.6 n/a fwd 14" meshies.
Will swap all 3 for something if anyone is intersted
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
