ok ive noticed lately somtimes evn when nthe ahdnbrake is off the light comes on, and when i boot it real hard it goes away, but sometimes when its off and i boot it it comes on
any suggestions ? my brakes are really low, is this some kind of warning thingy ?
I'd say your brake fluid is low - I think it uses the handbrake light as a warning light, and if your pads are low then it makes sense that your fluid is low too...
Have a quick look under the hood, you'll see it straight away if it's the fluid.
J
nah dont listen to them, ur car was an ex drifter, this light comes on cos ur handbrake setup had been changed and some wires may still be loose from when they changed it bak
scared yet? j/k
nath as jayson sed its the brake fluid warning
scared yet? j/k
LOL, 33s cant drift for shit :rofl:
okie ill get under that bonnet after ive fully woken up :rofl:
LOL - it's 1pm and your just waking up !!  Or isn't your brain working yet.....
Even when he is awake ihs brain aint working.
beleive you me. :rofl:
Nathan, as the others have said... and being that your pads/dics are LOW as.
There is going to be lessfluid floating around.
Hurry up and do the brakes :rofl:
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
