Just got my adjustable cam gears from Just Jap, and will be fitting them over the weekend, looking through a few threads (trying to use the search function incase this has already been discussed in past seven years etc) the basics have been retard the inlet, advance the exhaust. Is there a pretty common degrees that works? I understand engines are different etc, but, the standard cam timing on these engines are identical, and the standard cams are all identical, so surely there is a pretty well recognised adjustment. Car only has -7s and exhaust/filters. It will be going for a PFC and tune soon.
https://www.sau.com.au/forums/topic/364112-cam-timing-rb26/
when my car was tuned (stock cams, -7 turbos) tuner told me the inlet liked to stay on 0 and the exhaust got retarded 2 degrees (1notch) and made a tiny bit more top end
hmmmm... i'm pretty sure you'll find most people like the inlet moved on a few more degree's than that -should be able to pick up 300-400 rpm better response with the inlet advanced and without really any top end loss
if you've got adj cam gears, i'd have a play, you might have a bunch of midrange you're missing out on :)
  • Like 1
https://www.sau.com.au/forums/topic/364112-cam-timing-rb26/#findComment-5813396
  • 3 weeks later...
Retard the exhaust 4 deg and it will be on boost in no time, i'd leave the inlet at 0. You have nothing to loose retarding the exhaust just be sure to reset your ign timing.
I have played around with mine quiet a bit and the difference in lag from 0 to retarded 4 deg is awesome, it is MUCH more responsive but it might/will fall over in the higher rpm.
https://www.sau.com.au/forums/topic/364112-cam-timing-rb26/#findComment-5848292
no, he's right. you retard the exhaust cam, and yeah it makes a big difference. every car is different though but generally I've found with stock cams on a 26 you end up in the sweet spot somewhere between 2-4 degrees retard on exhaust side, and anywhere from 2-6 degrees advanced on the inlet side.
  • Like 1
https://www.sau.com.au/forums/topic/364112-cam-timing-rb26/#findComment-5851587
retarding the exhaust helps with top end generally, advancing the inlet helps response. I generally go small retard on exhaust but big advance on the inlet. Doing what chrisking666 suggested will work (same power curve but later) but wont have the benefit of the response.
  • Like 1
https://www.sau.com.au/forums/topic/364112-cam-timing-rb26/#findComment-5851689
  • 5 years later...
Back from the dead.
I confirmed 300 rpms earlier spool with exhaust retarded -4 deg (CRANKSHAFT degrees), and Intake cam advanced 6 deg (CRANKSHAFT degrees) on a 2.75L stroker w/ BW 8374 EFR .92 turbo with very little if any loss on top end. Gained MASSIVELY from 4k to 7k rpms (no kidding 30+ rwhp across the board). Same boost pressure (20 psi) on pumpgas.
  • Like 1
https://www.sau.com.au/forums/topic/364112-cam-timing-rb26/#findComment-7812525
  • 6 years later...
This is interesting... I was wondering why my setup wasnt making anymore boost. Maybe this related maybe not. I was looking at some of my pics and noticed the cam gears were at ZERO for both intake and exhaust.
My setup is BNR32 with a built 3.2, Hypertune FMIC bla bla, 9180 with 1.05 on a CNC head with 278/286 cams. On the dyno, we couldnt make anymore then 23-24psi. turbine speed was around 105k, and my EMAP ratio was higher, meaning turbine was being choked.
How would dialling in my cams change my power curve? It made only 530~awkw on around 23-24psi on pump. The turbo is rated to 900 theoratical, but Im only at around 800~ at the fly. Whenever he tried to add more boost, the fkn IAT would sky rocket.. even at 24psi, the IAT would be around 60~ by the end of the dyno pull. The tuner said he would check the cams but i guess he didnt, so im kind of annoyed... but the low down torque of this setup is nuts.
https://www.sau.com.au/forums/topic/364112-cam-timing-rb26/#findComment-7979649
So what you need to do is plot where this operating point is on the compressor map and see why the efficiency is so crap and what direction you have to go in order to get it to work better.
The thing is, just because a turbo is "rated" at 900, does not mean that you can reasonably make that amount of power on a given engine. Let's take an extreme position on this. Instead of a 3.2, let's say that you try this on a 6 litre version of an RB26. Same efficiency as an RB, just twice as large. It is going to make about twice as much power for any given boost level, right? Or, more to the point of this, it will take a lot less boost at any rpm to make a given amount of power. So, let's say you want to get 900HP out of it. How much boost is that going to take to do that? A lot less, right? So it will be way over on the RHS and down low on the compressor map. Down where the efficiency is shit. Can you actually make it work from that position? Hell no. Anything you do here is just going to make it walk up the map towards the right. In the same direction as the island on the map runs, but off to the RHS. If you add boost, it will flow more air and you go up diagonally to the right. It will always suck. It needs a bigger turbo, so that at the lower boost levels required to make the power, it will be closer to the middle of the island on the map.
So, with this 9180, I have no idea where you'll be on the map at 800HP, but I'm willing to bet it's the wrong place. What we'd call a bad match. I'm going to go play with matchbot right now to find out.
https://www.sau.com.au/forums/topic/364112-cam-timing-rb26/#findComment-7979652
    • Not yet, might end up being easter now, didn't end up getting time off over xmas.    I've been seeing some concerning things online now too. Lots of people with issues, could all be setup issues but the consequences in some cases are significant.    All of the below are other peoples stories, not mine and are unverified.  Seen 2 x broken adapter ring that destroyed the gearbox as it failed.   They still do seem to have twin plate rattle despite claims of silent. Several issues with it not holding power but some evidence of constant pressure on plate. Setup issues with bite point.   Lot of people after 2-4 weeks swapping back to another brand.    On the positive side, I've seen a barra put down near 1000hp at the wheels and its held it.  Also everyone seems to confirm the pedal is light.    Does have me a little cautious and looking at ATS carbon clutches again .......
    • I'm late to the party on this one but good to see common sense has prevailed and the turbo kit is coming.
    • She's looking good Greg. Colour suits it perfectly 👍
    • I had a look at the FAB9 EFR kit, around $8500 AU before delivery, so add in shipping, installation, consumables and tuning, I believe the price difference would be negligible  And whilst I am paying top dollar at MX5 Mania, if I have any issues with the kit they are local for support,  and from my experience, will happily go out of their way to help, hell, I've purchased parts from them and asked "how do I install or remove parts" and they have fitted a few of them for free, this means more to me than saving a few thousand dollars And yes, 99% of the time I just plod around in the car, that may change once I start hearing turbo whooshy noises, but, as I have 3 family members is the constabulary, even when I'm up it, it is only up to the speed limit, or occasionally, but rarely, overtaking on the Hwy (I just plod in the left lane typically and enjoy the drive) Plus the kids would never let it go if I got booked speeding, Jackie is constantly getting critiqued by the kids about her driving, which I think is hilarious, and tell them that she is "bringing shame to our family", so heaven forbid if I ever got done speeding, after all my mouthing off about her driving, I would never live it down, and it would be another thing she would bring up any chance she got Like the time I got drunk about 15 years ago and fell out of a cab, which gets brought up at least a few times every year since it happened Good times
