hey all im bout to buy a "hybrid" fmic 600x300x76. dose ne 1 know roughly what kind of price i will be looking at to get the piping made up for this? or has ne 1 had good bad experiances in adelaide with this?
also wanting to know what kind of boost increase i can do with the front mount, and what kind of power gains i will get?
i have a 1993 r32 gts-t m-spec with cat back exhaust and HKS pod. the boost is @ 12psi atm.
thanx guys.
a few guys on the site have got the hybrid coolers on their car and getting around the 170rwkw mark or more. with good tuning and full exhaust. with the stock turbo i wouldn't go past the 12psi for everyday driving, 14psi if you going down the strip. its the heat of the turbine blade spinning to fast where it actually mealts and stuffs up so. yeah. good luck with the cooler. on ebay you can get them for about 550.
i run 1 bar (14psi) of boost with cooler, exhurst, electronic boost controller...no idea about how much wk's its making...will take it to get dyno'd soon
OH make sure your fuel is all good...cos alot of those GTST fuel pumps are stuffed/ near stuffed. So when u boost it to 14psi on the dyno get them to check the fuel out.
you can pick up a hybrid 600x300x75mm for $700ish from justjap a sponser of this forum, www.powerdigger.com were selling the hybrid gts-t piping kit for $450ish or rolin imports (as you mentioned) here in Qld can get the same piping kit for around $600!!
Mate get it from the intercooler guy, he makes up the best looking best performing kits around for good $$ i just got mine yesterday and its the best ive seen, he is the most helpfun bloke i have met in the industry and will help you out with anything. 10 out of 10 for him, rollin is a bit overpriced but i got my rb20det half cut from them for ok price $2200
whos doin your piping bro?
and what kind of piping and for what car .. because im looking to get piping done too
ashmore exhaust at miami is the place, also the only place who quoted less that $800, all up $450 for all pipes, cutting body work, bends, hoses, clamps and labour, the car is in my avatar the engine is a silver top rb20det so had to go custome piping! the work is great and they even remounted the pod filter to a better spot using a bit of 3" piping!!
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
