Thanks for the endorsement guys.
This GTR is a Daily driver with all the fruit and yes it gets down and dirty and matches it on the track.
If you want something you can see your reflection in when you stand around at orange grove maccas, this probably isn't the car for you.
I posted up this link onto Prelude Australia. There's one mature guy (& senior member) interested in this I expect.
Hope Tim calls.
Thanks Terry!
Compression & leakdown test was done on the weekend:
Cylinder Compression Leakage
1 140 6%
2 135 4%
3 135 5%
4 140 3%
5 135 5%
6 135 4%
Ok I got 17k cash !!!
And I'm sure he has a 17lb brick for you too stop low balling every ad, this car is worth more then the asking price.
So take your 17k cash and buy a commonwhore
Was joking mate.. Don't need to use low level uneducated language.. what are you a hobo ?
Thanks for the love Champ!
