Before my Skyline i own a................................?
Time to fess up all, tell us what you all hooted around in before the ever superior Skyline.
For me it was a urrrrrrrrr compact 4wd with a toyota badge. hehehe I some how still managed to throw a conrod through the side of the block. :rofl: .......it wasn't that funny at the time.
https://www.sau.com.au/forums/topic/36416-finish-this-sentence/
  • Replies 41
I had a s1 gtst before this disaster i have at the moment
and a s14 before that
and a s2 gtst before that
and then a gsr lancer before that
and a lil ol import nissan sunny similar to the old 1985 pulsars
yaay
anyways i will be needing an r34 soon methinks
