Hey guys. Just trying to gather a few opinions and experiences on the greddy e-manage ultimate as opposed to the more common power fc. Will be purchasing computer for my R34 GTR so preferably someone who's maybe used one on the same car but any feedback would be appreciated. and yes, I have tried searching lol.
for BNR34 powerfc is bulletproof and cheap and you can buy it new plug and play for BNR34 with el hand controller
what is wrong with common?
common means there is lots of support (the powerfc faq, over 29,000 words, 154 pages)
common means there are lots of tuners (you can choose price and service)
common means its well proven and works
the bnr34 is such a nice car id hate to see you end up with an emanage mangled mess
why would you run a piggy back on a GTR?
i used to run an emanage ultimate - it was good for $500 and around 220-230kw BUT for anything above that you would want a standalone ECU.
personally, i wouldnt go for a power FC unless it was a bargain buy at under $1000. for the extra $600 i'd go for a link or vipec in terms of bang for buck. support for the vipec is direct with its creator, ray hall on the vipec website.
its simple to use and the add-on features are great (e.g. knock sensor, wideband for the auto-tune feature or logging, oil temp/pressure etc, boost control). and the help file ACTUALLY helps.
if your talking power specific, mines pushing over 285 awkw.. i dont have any problems with the eManage.
they are capable of pushing over 300kw... but at the end of the day you're after reliability when you're in the 250kw+ zone. for me it was fine at the 220-230kw mark but for some reason the r33 ecu didnt like the figures that were going into the MAF voltage table (for the MAP sensor conversion) and would pretty much shit itself when trying to tune. a lot of tuners wont touch them because its things like that, that make them a PITA.
best thing is to go to your tuner and ask them which ECU in your budget they prefer to tune. after all they are the ones that have to deal with it.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
