Hi i have my R33 series 2 skyline up for sale has 125 xxx on the clock also
has rego till Nov 2011
it has the following been done to it
Full Jun style body kit
3 inch turbo back exhaust system
3 inch hi-flow cat
Aftermarket front mount intercooler
HKS mushroom pod
Spitfire coil packs
White face dash cluster (illuminates blue or green)
6000K HID's
Just Jap front strut brace
Cusco Rear strut brace
Pioneer cd player
Pioneer front speakers
Jaycar rear speakers
Nismo smoked side indicators
Smoked rear lights
17" jap mesh style rims (staggered fitment)
Alarm system and immobilizer with built-in turbo timer
Walbro in tank fuel pump
Car is tuned by Toshi at 10psi.
Paint is metallic silver. not overly glossy, but not matt either. best to come look at it.
contact
steve: 0433045092
https://www.sau.com.au/forums/topic/364183-r33-series-2-skyline/
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
