ive just fitted a new fuel pump and need to tune the fuel curves as theyre rich as hell and all over the place
what would be a better option, the SAFC or a remap?
given i will be modding the car a bit in the future....
im running a bosch 910 pump and a garrett T04E with ex gate + all other normal mods (zorst, pod etc)
thanks!
adam
https://www.sau.com.au/forums/topic/3642-safc-or-remapped-ecu/
Does diconnecting the battery reset the SAFC as well as the ECU?
no you can even remove the s-afc and it will keep teh same settings
some things to consider when using an s-afc you will need a boost cut defendeer if you plan to run more than 12 psi and timing changes could help you get more power.
. If your aiming for 160-70 rwkw then s-afc is fine 200 + then look at the power fc
meggala
No need for PowerFC for me, I'm not aiming for 200+ at all. I dont often drive that hard so it makes no sense!
I think 170 - 180rwkw is my target.
OK, if the settings are permanent, then I'm happy with that. Only thing is I'd like to have it in an inconspicuous position where it's well hidden! I dont want theives breaking my windows, and cops breaking my balls!
the e-manage is discrete, and for $450 is cheaper than the S-AFC with the options of upgrading it.
Originally posted by meggala
rev 210 tell me where I can by a emange with harness software sensores etc for 450 brand new.
meggala
nengun flogs the e-manage for $450AUS. The harness and software are extra, but I thought this guy just wants the functions of the S-AFC. If so the e-manage in its $450 form does the same thing. Anyway you can buy the E-01 boost controller later on and do away with the need for the harness and software.
Even if you wanted to use it in the same fashion as an AFC, wouldn't you still need the software to tune it?
thats only another 250 from here in australia... which makes the total 665 which is about what it is just to buy the e-manage unit itself... u do the math :D
no you don't need the software to tune it in afc mode.
The software allows FULL mapping of fuel and ignition blah blah blah just like the PFC etc.
