ive just fitted a new fuel pump and need to tune the fuel curves as theyre rich as hell and all over the place
what would be a better option, the SAFC or a remap?
given i will be modding the car a bit in the future....
im running a bosch 910 pump and a garrett T04E with ex gate + all other normal mods (zorst, pod etc)
thanks!
adam
https://www.sau.com.au/forums/topic/3642-safc-or-remapped-ecu/
Does diconnecting the battery reset the SAFC as well as the ECU?
no you can even remove the s-afc and it will keep teh same settings
some things to consider when using an s-afc you will need a boost cut defendeer if you plan to run more than 12 psi and timing changes could help you get more power.
. If your aiming for 160-70 rwkw then s-afc is fine 200 + then look at the power fc
meggala
No need for PowerFC for me, I'm not aiming for 200+ at all. I dont often drive that hard so it makes no sense!
I think 170 - 180rwkw is my target.
OK, if the settings are permanent, then I'm happy with that. Only thing is I'd like to have it in an inconspicuous position where it's well hidden! I dont want theives breaking my windows, and cops breaking my balls!
the e-manage is discrete, and for $450 is cheaper than the S-AFC with the options of upgrading it.
Originally posted by meggala
rev 210 tell me where I can by a emange with harness software sensores etc for 450 brand new.
meggala
nengun flogs the e-manage for $450AUS. The harness and software are extra, but I thought this guy just wants the functions of the S-AFC. If so the e-manage in its $450 form does the same thing. Anyway you can buy the E-01 boost controller later on and do away with the need for the harness and software.
Even if you wanted to use it in the same fashion as an AFC, wouldn't you still need the software to tune it?
thats only another 250 from here in australia... which makes the total 665 which is about what it is just to buy the e-manage unit itself... u do the math :D
no you don't need the software to tune it in afc mode.
The software allows FULL mapping of fuel and ignition blah blah blah just like the PFC etc.
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
    • It's all the sound deadening, and extra shit piled into them, plus all the extra (even though it's thinner) material for crumple zones. I can't fathom in modern cars why they need canbus to the headlights, and why the headlights must be vin coded on some cars to the ECU, BCM, and security module! Especially when they claim it's for security, yet, the canbus at the headlights let's thieves steal the car in minutes, so even more cars are being stolen! The Mercedes Sprinter 907 vans. They're a huge van, but a "basic" van. Yet they have that many canbus networks, plus two Lin networks, AND an Ethernet network. Logging a single network alone of 8 byte data frames, and they will generate a 20mb log file in 5 minutes. That's one network, and I can't remember the exact amount, but there's over 10 full CAN2.0B networks in them. I'm not a fan of modern cars, oddly, more and more I hate DBW, and all the bullshittery the cars try and interfere with. But all that bullshittery adds weight, plus crazy regulations on crumple zones, plus, ever picked a modern seat up, half of them have like 4 electric motors in them and will weigh 30+kg each. Then all the motors for things like adjustable steering columns blah blah blah. And did I mention the sound deadening so you can even hear an ambulance right behind you even if you 7.2surround sound is off?
    • Ah ok, yeah it should be flat, I believe the r34 battery tray has these 3 bumps in them they makes it line up and everything is flat, don't see how it would tilt if everything is secured.
