Hey Guys,
I thought this would be relevant to a few people around these traps.
So, you've got a R33 with a stock bonnet, you're doing track days so you need a secondary bonnet restraint.
This is how you do it
Step 1. Buy this junk.
1x Meter of 3mm galvanised chain. = $3.77
1x Snap Hook 60x6mm = $4.18
2x D shackle 5mm = $1.47
I got mine from Roberts Hobart on Collins Street.
I cut my chains so one was 48cm long, and the other was 17cm long.
Loop the long one through the top holes, I used a piece of wire to help pull it through.
Loop the short one around the bracket that holds the stock latch in position. I could poke mine through the radiator shroud because it was already damaged, you might need to be a little more crafty.
Then clip the Snap Hook onto one of the ends and it's all done. :D
I hope this helps a few people.
Edited by zoidbergmerc
Made a couple of these a while ago, just be aware that the weakest part of the thing is the snap hook on the end which are not rated that high, so you can go smaller chain, I found all this info on the Bullivants web site
Still got some left from selling them at events for $10.00, if your in Sydney and could be bothered Ill give you one for free.
The D shacles bolts onto a existing hole on the stock bonnet lock mechanism and the spring clip hooks onto the male section on the top of the bonnet, when open it allows about 80mm gap to get a fire extinguisher in.
Rated to 250kg
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
