For sale... Fiberglass front diffuser to suit R32 GTR (brand new)
This diffuser will improve airflow under your car to increase front down force, while also channeling air to your front brakes.
This will also fit a GTSt, but if you're running a standard front bar you will need to modify the attachment hardware to raise the height, to match the bar.
I've been running one of these on my car for the last couple of years, but recently had to change the front bar due to an incident with a Wallaby. I bought a second diffuser as I thought I'd have to modify the attachment points to suit the new bar, but as it turns out I didn't need to use it.
So I'm just trying to get back what I paid for it.
$250 + $25 postage Australia wide
Local pickup is available from Nowra, NSW.
https://www.sau.com.au/forums/topic/364256-r32-front-diffuser-brand-new/
im keen but what a pain to change the oil
There's a little window that is held on by two scews to access the oil drain plug. If you look carefully at the first photo, and you'll see it.
I haven't found changing the oil to be a hassle.
Have you got a photo of it from the front?
+1 to this.
Does it replace the N1 Brake vents? A pic from the front should clear up any questions that i have! Cheers :)
Here's a couple of photo's of my car from the front.
Please note though that my front bar in an aftermarket fibreglass one, and not a standard GTR bar. The front of the diffuser is hiding underneath the splitter extension I glassed onto the bar.
Are these designed for the standard N1 front bar? Will it sit flush with the N1 Lip or what?
Yes it is designed for the standard R32 N1 front bar (see the 2nd photo, in the first post)
I can't see why it wouldn't sit flush with the N1 Lip, though I haven't personally fitted one to the N1 bar.
With a little modification to the attachment points you can modify this to suit almost any R32 front bar, as I've modded mine to fit two very different bars on my car.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
