I am thinking of putting an alarm into my r33, and i have done some research, for the central locking part we will need an actuator for the driver side,
and i noticed that most of the alarm systems dont come with an actuator, does that mean i have to get my own one?
and is there any wiring diagram for r33 here?
cheers
https://www.sau.com.au/forums/topic/364304-alarmcentral-locking-on-r33/
  • 3 weeks later...
yes your car needs a door motor on the drivers door you can buy a single door motor kit from jaycar and can be used on most alarms i do hundreads of skyline alarms in sydney any questions just ask me
alright if you've seen hundreds of skyline alarm installs maybe you, or anyone could help me with my problem.
i was trying to install extra LED lights on to the light that comes on around the key ignition thingy when you unlock the car and turns off after approx 10sec of shutting the door (not really sure what thats called) but i think i shorted it but without blowing a fuse... theres still a little bit of power going to the light but not enough to fully power it or any others.
and i have no idea what i've done.
sad face.
what version 33?
and for the fellow that's done hundreds of cars - ABN or employer please..
I can vouch for hundreds of them - been working on these cars for the past 11 yrs.
if its a S2 then you have probably popped the smart entrance module and that's not a good thing.
  • 4 weeks later...
Adding an actuator to the drivers door is one option but a poor one. The angle at which you need to mount the aftermarket actuator makes it unreliable. The actuator rod that conects to the original door locking rod will snap off after a while.
A beter option is to tap into the existing system. The car already has actuators in both doors and they work well. The trick is to feed a signal into the central locking module from the new alarm. I think I can figure out the connections if I had a circuit diagram for the R33. I have been searching for ages now for this circuit diagram, but no avail. The "chassis" manual for the R33 is rare and no electronic version seems to be available online. Those who have hard copies are keeping the manual close to their chess!
chris the compliance shop that did my car wired the drivers convience module out of the loop, I had to open up the drivers door to find the hack they did to over ride it. pm for how they did it.
returned it to normal now . also the light around the key surround is easy to fix. I changed mine to Blue LED, looks way better now.
done heaps of r33s and only ever seen 2 with a factory door motor in the drivers door and you can put the aftermarket door motor dowm the bottom and it lines exactly up strait and have never had any problems or had to go back and fix any they all have a factory switich not motor even 32 33 and all 34s have a factory motor exept n1
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
