hi guys, have trouble starting my 32 GTS-t (RB20DET) when its cold and runs poorly till its warmed up a bit, took out the sensor with the yellow top ,near front of manifold ,and its broken! is this the cold start sensor and where can i get a new one in perth?
https://www.sau.com.au/forums/topic/364342-cold-start-problem/
if its the one in top radiator hose (solid section that bolts to the motor) then its the coolant temp sender for the ecu and will cause some problems if its farked. not sure where you can get a new one but could try a second hand one, they're pretty reliable
if its the one in top radiator hose (solid section that bolts to the motor(YEP IT IS THAT ONE)) then its the coolant temp sender for the ecu and will cause some problems if its farked. not sure where you can get a new one but could try a second hand one, they're pretty reliable
yar,very cautious bout using secondhand 20 yo sensors ,mite be as borked as mine but looks like that might be the way i hafta go
thanks for that guys, will give repco a go as they are just up the road from me
Don't bother with repco, I work there, we don't stock such a part for an import. Each store would be 10x the size it is if we stocked something specific as a coolant temp sensor for an imported skyline!
+1 for nissan.
+1 for nissan.
i tried repco joondalup and they dont stock tridon stuff BUT he cross referenced it with another catalog and reckons a pulsar N15 one is the same and costs $43, will compare that price with DVG parts in bassendean when i givem a call monday
I have one that I no works u can have for 20 if u come pick if up txg or call 0411698969 cheers brenno
hi brenno, thankyou for the offer but i will try the new option first and give you a call if that falls through, thanks mate
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
