Well I'm putting out 600hp in my gtr through n os giken 5 speed, cruise on the freeway every morning and afternoon for work n I don't have a single problem with the ratios if the box.
I don't see any point to this at all other than that fact u can brag to your mates that u have a 6 speed box thinking that it's something exotic n rare. From what uve said it's just pure wank factor. I doubt u would notice any difference when driving
That is my observation of what u want
  • Replies 86
I won't deny that 3/4 of wheels, body kits n paint is a wank factor, but those are only cosmetic things, not mechanical. U do mechanical things on a needs basis not just coz it's "cool"
This is a very costly excerise with little to no gain.
Getrag gtr box. Roughly $4500-5000 last time I checked
Then ull need the r34 gtr rear diff to suit the boxes ratios
Remove transfer case
Make custom adaptors
Make custom tail shaft
New clutch to suit larger input shaft of the getrag
I'd pull the box down n check everything is 100%
Labour costs
New parts if things arnt 100%
Add all this up and it quickly becomes not worth it at all.
Labour costs
Strongly disagree with people doing mechanical things on a needs basis. I didnt put a full zorst on my car because it needed it- rather i like the sound and power increase. And thats without talking about all the useless shiny engine compartment parts that people spend there money on.. but last time i checked its up to the owner of the car how much money they spend and what on, after all isnt it all about the driver of the car being satisfied ?
Dont get me wrong, i wouldnt spend 5 plus grand on a 6 speed box myself, nor would i spend 10 plus grand on a f**king paint job- but its not my money, and if its worth it to him then who cares?
Define worth? Making a $7,000 bad choice is something i don't like seeing any user do - and that's exactly what it is.
Stock ratios i can get 650-700km to a tank on the freeway - cruising @ 130km/h too mind you which is around 3300rpm IIRC.
Sounds like it might be an economy choice or something.
A Supra Getrag is still just as expensive as a GTR Getrag simply because anyone wanting to convert their Auto to a 6-speed needs the box - So they are potentially more expensive. It'll be around 6-7k adventure just for the extgra gear, that offers no performance benefit either.
Lot of cost just for a want. If going 6-speed was a good idea, everyone would have done it.
I mean full credit to him for persisting with an idea. It's just hard to fathom as to the reason you'd spend that money when the gearbox is worth more than the car.
mate when i have completed the engine and everything else, i would LIKE to put a 6 speed in, just something i want to do, and i dont no if someone has changed my diff ratios but cruising at 130km/h im doing aqbout 3900rpm - 4000rpm , at about 100km/h im doing 3400rpm
and how could it all cost 7k theres 6 speed boxes out there for 1.5k - 2.5k , my mate can mill me an adapter plate (he just finished my plenum)
so thats free (maybe a six pack) driveshaft ? im not sure maybe $100 - $200
fitting $0 just an hour or two with my mate , and a jack,lift, thing
new uni's, if that, couple hundred
total cost max 3k and an arvo of playing around fitting it,
wow dont know where u been looking for boxes, can u provide a link to these cheap boxes? all the ones ive seen on here have been $4500+ considering its about $8000 brand new
import monster has some for $4500 delivered
new twin plate clutches go for anywhere betwwen $1500 for a cheap one up to $2500 for nismo copermix
u want to race so a new diff is required say about $1800- 2200 for a 1.5/ 2 way
drive shaft will be more than your quoted 1-200
will need to be ballanced also
oils, theres another $200 or more for diff and box
so far ive added up ull be over $8000.
have u driven a six speed before and did it live up to everything that u say it will?
do u have a hoist also? gear boxes are heavy n i wouldnt attempt to install one only on jacks.
you honestly have to weigh up if its worth it? u may do all the work n find out its not all u make it out to be.
listen to the people on here, they have tones of experience and have learnt lessons from others, all we are trying to do is let u know that its not worth the effort
Where are you getting a Getrag for 1.5k?
They are $4500 minimum. Fact.
If you are looking to 'adapt' a 6-speed out of some other car like a S15 or something, you should stop that idea right now as you are going backwards. They are not as strong. There are other factors you've not thought of like speedo calibration/signal/ECU, gearbox mouting, possibly tunnel changes, 100% custom driveshaft will be a LOT more than 200, clutch to suit it all etc etc.
It's not as simple as you are making out dude, nor it is cheap. :/
Anyway you don't really seem to have a good idea of whats involved so I'm out of this thread. Good luck with a 6-speed conversion.
i looked around on this topic when I first seen it for shitsngiggles and found a thread from America.
http://forums.nicoclub.com/tremec-tranny-for-rb-t448047-40.html
Basically guy was all set to make a Tremec T56 speed adapter kit ( I beleive if you were going to do this the Tremec T56 box would be your best option as its strong and readily available pretty cheap, about 1500-2000 as you said ), he had it all drawn up and was getting prices, all he needed was enough people in a group buy to make it happen..
It didnt happen!!
So I think you should do it, then report back here and tell us all how good it is..
yeah at first I was with the haters as well, I thought its a pointless and fruitless excercise, I still do. i mean what is really to be gained from this,
A bit more top end speed? maybe but how fast are you driving
fuel economy? Well only on the highway maybe, put with the cost of the conversion its self defeating
But if I wanted to see someone spend/waste money on a car I would rather see someone do this than spend/waste 5000$ trying to fit an ugly as aids veilside bodykit
Tremec T56 are a decent box at roughly the same price s/h as a r33 5 speed, if there was a conversion kit for lets say under 1000$, im sure many people would consider it as well. But without a ready made conversion its alot of work and not for the fainthearted or those without engineering skills or a fat wallet
But Ash is right this guy has no clue whatsoever so I was just daring him to do it cause I know he wont :D
thank you some one get its, i wouldnt spend 5k plus on this conversion, i didnt no the cost,
that why i asked for info,
cheers
http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Nissan/Gearboxes/auction-377193620.htm
you realise you will have to find a stupid high diff ratio . something close to 3.5 . as 5th is 1:1 not 4th like a normal box . giving you 4 under drive gears
same as when you put a 2jz and r161 box in a silvia 1st gear becomes useless unless you g
get a tremac t56 .
not sure about the other boxes but T56 still has 1:1 in fourth, 5th is overdrive, 6th is warp speed :D
Only the Commodore and Dodge Vipers had those silly ratios.
There are about 12 million ratio combos avaliable for the clunky old T56
Yeah all 1:1 forth like most gearboxes, but 6th in the VT-VX commodores was 0.5:1 yup double over driven.
Would be absolutley useless in a skyline, if 400rwkw supercharged V8s cant accelerate in 6th with a 4.11:1 diff, than a 2.5L six has no hope
This is one of my pet hates on SAU.
Some one makes a thread for other peoples opinions because they have very little knowledge on the subject (completely fair, that's the purpose). However when the people with the experience and knowledge tell that person it is a bad idea and will cost $10,000 the OP starts getting cocky and having a go at people.
I don't get it.
Why make the thread then?
I'm not trying to give you shit. I just don't get it. Obviously you had no idea on the subject so why not take peoples advice straight away?
Also people comparing some one spending money on wheels/kit/etc. as been in the same boat as this gearbox conversion doesn't get the point and it is nowhere near the same.
Also to this:
and i was thinking twin high flowed rb26 turbo setup
550 cc injectors, tomie poncams, cam gears,
anyone think of anything to build an awesome engine
Im building an rb30/25 (about 40 percent done, engine runs pretty good but gutless still stock n/a ,atm, now its time for the mods.
This to me sounds like you once again have very little information. You do know that the RB26 turbo setup won't bolt straight up onto a RB25 head? If you wanted to do that you should have just started with the RB26 head. Would have been a lot easier.
And as others have said. Start this with a GTST. All people that start these projects with a GTS end up regretting it because it ends up costing more than if they had started with a GTST and the GTST has a lot of extras in it over the GTS.
Also how do you build an engine when you don't actually know what the setup for it will be? What CR have you built it to? And how is it 40% done, but running and being N/A? Is it in the car running but you have bolted all the NA gear onto it for the time being?
Just my 2C.
    • Just something I found searching for more info on Emotion R, apparently the ECR33 Skyline GTS25t was either originally black, or there were two of them, the black one being the original demo car, then building a white one which was part of the 1997-onwards (to at least 2008!) Cockpit Tatebayashi Tokyo Auto Salon booth demo cars. It appears that Emotion R closed down in 2008 and was declared bankrupt in 2010: http://bank-db.com/hasan/208365. Scan of a magazine with the black R33 from 1996: Wayback machine archived page from May, 2000: https://web.archive.org/web/20000529061027/http://www.emotion-r.co.jp/skyline.html Option magazine with a few photos from the Cockpit Tatebayashi booth at the Auto Salon from various years: 2002: http://www.jdm-option.com/photo/index.php?action=item&category_id=154&image_id=3507 2003: http://www.jdm-option.com/photo/index.php?action=item&category_id=137&image_id=3033 2005: http://www.jdm-option.com/photo/index.php?action=item&category_id=116&image_id=1831 In 2008 Cusco website mentions that the Cockpit Tatebayashi ECR33 was displayed at that year's Tokyo Auto Salon: https://www.cusco.co.jp/event/2008/12/post_735.html As of 2021 it appears that the ECR33 demo car ended up being exported to Florida, USA: https://rmcmiami.com/inventory/1996-nissan-skyline-r33-cockpit-tatebayashi-demo-car-big-te06-turbo-endless-brakes-lsd-450hp/ And finally here's Google streetview of the Emorion R garage in 2023 which is amazingly not only still there, but the showroom is still full of various parts in stock and funishings, etc.: https://maps.app.goo.gl/ttyEAZdZLyzermyT9 Apologies for nerding out a bit. I used to love doing this 20 years ago on SAU and got a bit nostalgic for a moment... 😅
    • Try fabricating something like this and install it under the pedals? Not sure if it's legal or not....
    • Even though I have some pretty good (brand) ratchet ringies, I avoid using them to break open tight bolts. A broken ratchet is very annoying.
    • Also, there's always room for 4 or 5 3/8" drive wobble extensions of various lengths so you can operate the ratchet from a better location.
