I am selling these items due to a change of direction, i now have a r33 and these have no use to me,
i bought all the items at $750, you can buy the lot for $500. my loss is your gain, Call at any reasonable time.
I am not seperating any further that what i have listed
Part: S13 Lower control arms, hubs and knuckles (will come with s13 power steering setup, mostly complete)
Condition: good condition
Description: Comes with every thing you need for a good suspension setup in your 31 or your other project drift car (some bolts missing, and one ball joint just needs a rubber cover as the one on thernow is ripped)
Contact Details: 0422334013
Asking Price: 200 firm (no offers please)
Pick-up/Postage Arrangements: will post if you organize freight and i will drop of at courier, providing its not too far.
PICS
http://s736.photobuc...xx1/adam999111/
Part: S14 4pot calipers with QFM700 pads (80%) & NEW 280mm S14 slotted rotors drilled to 4 stud
Condition: excellent condition
Description: Comes with every thing you need for a good front brake setup in your 31 or your other project drift car
Asking Price: $300 firm (no offers please)
Pick-up/Postage Arrangements: will post if you organise freight and i will drop of at courier, providing its not too far.
PICS
Edited by adam999111
    • Found it thanks, the front tie rod end should be torqued to 40nmish
    • Ok I thought my allow had a flat back but it does have grooves for the spacer nut/ no cutting needed   bolt and nut sticking out from the spacer around 12mm and the groove is around 24mm so all good   appreciate the help chaps
    • Back in 2016 bought a set of front and rear bracket set and changed all 4 corner discs and caliper   i was checking the car and seen rust like or in another word crumbled part of the bracket which came off with a air blow   is this normal? This had happened in two areas and car from 2016 has mostly been in garage/ doing less than 2000 miles over past 8 years or so pic with areas highlighted in red   https://ibb.co/NtmWXZt   also anyone knows the torque spec for the bracket as want to retorque them, one bolt had come off half way !
    • So if I was to spend 400r money and remember I am only here because I need 4 doors because of an incoming kid otherwise I would be looking at a lexus RCF what am I loosing out on other than fuel economy but gaining in power and space / V8 sound on Chrysler 300c STR Vs nissan 400r?, I will admit that buying the VE bomadore was an eye opener into build quality compared to Jap cars... https://www.carsales.com.au/cars/details/2020-chrysler-300-srt-core-auto-my20/SSE-AD-18201088/ but this one is on the same money...
    • If you're friendly with a workshop that has a large scraps bin you can always ask to dispose of there. Otherwise theres always the places like sims metal etc depending where you are at https://recyclingnearyou.com.au/cars
