i will be using these to shortenthe words i use:
REC P = Recommended Plug
IRID = IRIDIUM
for the R30 owners
1981 - 1985 L24E
Recommended Plug - BP5ES-11
IRIDIUM - BPR5EIX-11
1981.8 - 1985.8 L20ET
REC P - BPR5EIX-11
IRID - BPR5EIX-11
1983.2 - 1985.8 FJ20ET
REC P - BP6ES-11
IRID - BPR6EIX-11
R31s +
1985.8 - 1987.8 RB20DE
REC P - PFR5A-11
IRID - BCPR5EIX-11
1985.8 - 1987.8 RB20DET
REC P - PFR5A-11
IRID - BCPR5EIX-11
1986 + RB30E
REC P - BCP6ES-11
IRID - BCPR6EIX-11
1986 - 1988 RB30ET
REC P - BCPR6ES-11
IRID - BCPR6EIX-11
1987.8 - 1989.11 RB20DE
REC P - PFR6A-11
IRID - BCPR6EIX-11
1987.8 - 1989.5 RB20DET
REC P - PFR6A-11
IRID - BCPR6EIX-11
1989.5 - 1991.8 RB20DET
REC PFR5A-11
IRID - BCPR5EIX-11
1991.8 - 1993.8 RB20DE
REC P - PFR6A-11
IRID - BCPR6EIX-11
1991.8 - 1993.8 RB20DET
REC P - PFR6A-11
IRID - BCPR6EIX-11
1991.8 - 1993.8 RB25DE
REC - PFR5K-11
IRID - BCPR5EIX-11
1993.8 - 1998.5 RB25DE
REC - PFR5G-11
IRID - BKR5EIX-11
1993.8 - 1998.5 RB25DET
REC - PFR5G-11
IRID - BKR5EIX-11
1998.5 - 2001.6 RB25DET
REC - PFR6G-11
IRID - BKR6EIX-11
1989.8 - 1995.1 RB26DETT
REC - PFR6A-11
IRID - BCPR6EIX-11
1995.1 - 1999.1 RB26DETT
REC - PFR6A-11
IRID - BCPR6EIX-11
1999.1 + RB26DETT
REC - PFR6A-11
IRID - BCPR6EIX-11
www.ngk.com.au
The "Reading the Plugs" part.
NORMAL
pic01.jpg Light grey or tan deposits and slight electrode erosion.
CARBON FOULING
dia_carbonfouling.jpg Dry, soft black carbon on the insulator and electrodes.
Symptoms:
- Misfiring
- Poor starting
- Faulty acceleration
Causes:
- Delayed ignition timing
- Faulty choke - over rich air/fuel mixture
- Bad ignition leads
- Plug heat range too cold
PRE-IGNITION
pic03.jpg A melted or burned center and/or ground electrode, blistered insulator and aluminum or other metallic deposits on the insulator.
Symptoms:
- Pre-ignition occurs when combustion begins before the timed spark occurs
- Loss of power causing engine damage
Causes:
- Plug insufficiently tightened
- Engine insufficiently cooled
- Ignition timing too advanced
- Plug heat range too hot
OVER HEATING
pic04.jpg An extremely white insulator with small black deposits and premature electrode erosion.
Symptoms:
- Loss of power at high-speed or during heavy load
Causes:
MECHANICAL DAMAGE
pic05.jpg Bent electrode an a broken insulator, dents often present on electrode.
Symptoms:
- Misfiring
Causes:
- Plug nose is too long for engine head
- Foreign object (bolt/nut) in combustion chamber
OIL FOULING
pic06.jpg Wet, oily black deposits on the insulator and electrodes.
Symptoms:
- Poor starting
- Misfiring
Causes:
- Wrong piston rings, cylinders, and valve guides
- Fuel mixture oil content too high (two-stroke engines)
BROKEN INSULATOR
pic07.jpg Insulator is cracked or split.
Symptoms:
- Misfiring
Causes:
- Severe detonation
- Incorrect tool/torque applied during installation or removal
- Careless gap setting
TORCHED SEAT
pic08.jpg Melted in the thread and seat area of the plug housing.
Symptoms:
Causes:
