40 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
That's not that amazing tbh. I've heard of people hitting around 4500-5000rpm in 4th gear at 170 in a bone stock car.
my friend reckons he took his mums excel to 220 or something on a freeway.. they take a fair beating.
I took mine to 180 when I was 17. Totally not worth it.
was just saying that NA skylines really lack in the performance aspect, even a crummy old hyandai excel has a top speed faster
  • Replies 58
180kmh @ roughly 5000rpm in 5th gear and struggling to get any more speed out of it. Did have the speed limit cut out on it too. Done on the track ofcourse
So it doesnt have a limiter ??
I know my 32 (auto) is limited to 180 and definetly wont go any higher then that.
Even at 180 it physically doesnt feel like it could get much higher then 200 (although a rb25de would have a bit more grunt then the shitty rb20de).
i got about 160kmh on 5000rpm gear 5, don't know if it would go any faster the car was vibrating lots
I did 170kmh twice... the car nearly fell to pieces when i was braking :rolleyes: I would try 200kmh on hwy with my RB25DE once i decided to suicide.
really only 170/180 kmh, fastest ive gone is 140 kmph Comforatbly in an AU falcon, easily coulld go over 200 imo.
I've gone past my speedo (180km/h) in my na 34, can't remember the rpm. Was a bit surprised thought it would be limited at 180.
what speed did you end up hitting?
you have to take into account error in the speedo unit. from my experience in multiple imports, generally the speed limiter kicks in at an indicated (approx) 190kmh. this is because they often factor in a few percentage over read so that the speedo reads faster than the actual speed so that you don't get booked so much (and because it is a legal requirement from what i gather)
All of the factory maps I have looked at have the speed limiter set to 178kmh, there will of course be a discrepency in speed between what the wheels are actually doing and what the speedo says, depending on tyre sizes and how lazy the speedo is.
exactly what i said.
i should also point out that when i had my 33 on the dyno it hit the limiter at 180kmh by the dyno speed reading, but it was past it on the gauge.
  • 2 months later...
I hit 170 in my ca20e equipped Nissan pintara, was pretty damn scary in fwd. I now have a N/A r34 and on a dyno run it went off the clock completely at 7400rpm. I had it at 150 at one stage on the road and the speedo needle was still going strong. I don't think it would have any problems getting 200.
im getting my flame suit ready, but i think all this chat about the max speed of an n/a skyline is just pointless ... you wouldnt buy an n/a skyline to go at speeds above 180km/h, thats how i think about it anyway...
getting to 150kmh is easy. getting past 180kmh is a lot harder.
and don't pay much attention to how fast a car speeds up on a dyno. for starters there is no aero drag and that is one of the biggest factors in top speed. that said, a natro skyline would do over 200kmh, but it will take a bit to get there
Yer i dont really get it either man... but saying that, with with speed limiter removed the RB25de will do over 200 but dont expect it to get there in any great hurry.
Its not about how fast you can go its about how fast you can get there. Hitting 200km/h in a DE, the turbo counterpart can probably hit 200, stop, then do it again in the same amount of time.
That said some dick I know has a Yaris, he used to do M4 driving at 180km/h, smooth as f**k lol.
  • 3 weeks later...
I've got where 190km/h would be on the speedo in the rb20e, but I tried again by just flooring it in 5th and as soon as I hit 180km/h the speed cut kicked in. Think it was because I reved it to 6800rpm in 4th the first time and I think thats past 180km/h then changed to 5th. Yes it's slow.
ive hit roughly around 190 as it reads on the speedo before the speedlimiter kicked in the the car just rapidly decelerated to around 160 even with my foot flat to the floor. 1st time i tried it, i thought i blew the engine lol
that won't make a scrap of difference as the ecu simply goes off the speed sensor. it doesn't know what gear you are in (and it doesn't care). my 180sx used to hit the speed limiter in 4th.
and to do that in a car with a rb20e, you must've had a good tail wind going down a steep hill, lol
I got an r33 GTS4 same stock engine Ive got no problem getting to 170 and then it just seems to crawl at snails pace up and ran out of road . . . errr track so slowed at 175. I think mines a fair bit weightier but I had always thought that would mean less accelaration and wouldnt affect top speed as much. I know its not alot to many people but ive always wanted to hit 200.
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
