  • Replies 169
Posted Images
Couple of front drivers that come to mind
Sunny Gti (non turbo FWD) has been past state champ and regular 2wd champ (has a big HP SR20DE)
Mirage Cyborg (the one and only Kel nav's in this one!)
This was the first gravel car I navved in
Surprisingly quick for 1.3 litres!
But with all the front drivers they just have to have an LSD and a close box to be remotely exciting (as the three I listed above all have).
Edited by PHaT MR30
LSD is the tricky part, ours has the 4 speed with a high/low range thingymebob.
No LSDs avaliable for the thing, and I doubt a front driver would like a welded centre lol
FWD's regularly punch above their weight on the loose stuff.
Stock standard Excels hose much "faster" cars regularly. In my Civic, I usually take out my class (U16), as well as top 3 in the U2L and O2L in the 2WD categories, as well as a few of the AWD's in the dirt sprints I attend. Might be a different story in the forests, but I know that with a good steerer, my car is capable of top ten finishes at state level.
Well set up and driven FWD rally cars will almost always be quicker than their RWD cousins. Heck, I've seen some unlikely FWD's hose faster RWD cars (including a bock stock TR Magna auto)
You don't need a LSD and CR box, but it always helps. The general consensus is that a welded diff in a FWD is a very bad idea.
Well setup means $$$
I dont like spending $$$ lol espesially on a car that MAY have no potential what so ever
The thing im worried about is the lack of parts for a a Cordial...I mean when was the last time you saw a cordia compete in....well....anything?
It is something I will have to discuss at length.
Under PRC Regulations they aren't eligible, due to capacity...
Are you sure? I haven't looked at the PRC rules in a while, but back when I was rallying i don't think there was anything in the rules to stop a GTR from being eligible.
Edited by hrd-hr30
Zebra, get in touch with Danny Murphy from DMA motorsport in Melbourne, tell him Ian Plendo sent you... He ran a turbo Cordia for a while, with very little success... The prob was with it being turbo and torque steering, he may have some good ideas as to setup. FWD is HEAPS better on dirt as long as you do it right. PM me when you are doing an Amsag and I will come say hello, spent 2 years rallying a Camira (1 in amsag) and 2 years in an AE101 levin including winning the NSW p2 championship. Then moved onto AWD. My hint would be to look into limiting the amount of steering lock, this will drastically extend the lifespan of your driveshafts. We do it by getting nylon spacers in the end of the rack.
The other thing is to get a feel for using your left foot on the brake, trick is to brake in with your right foot so you can use the clutch, then once you get the nose in go to left on the brake. I never actually used the handbrake much.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
